Lands End Trial 2020
Moderator: Event Co-ordinator
Re: Lands End Trial 2020
Hmmnnn...I'm obviously being dull. I've joined MCC, registered ACU but now seem to be in the situation that one wont let me progress without the other, Catch-22. Helplines not manned at the weekend so I'll try again on Monday.
‘10 BMW K1300GT
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
Finally cracked it! Philip and Andrew, see you there.
Captain Darling, “I wouldn’t worry about it too much Blackadder. Flying is all about Navigation, as long as you have a good Navigator, you’ll be fine.â€
Enter Baldrick, stage right.....
‘10 BMW K1300GT
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
- arceye
Jolly good.
See you at Popham.
Then hopefully we all get to the finish and be greeted by Lardmarc with yummy Cornish pasties.
See you at Popham.
Question: Is the road book in miles? That’s going to be quite tedious converting all the distances into km if it is or do I not need to worry about that?
‘10 BMW K1300GT
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
- arceye
Yes, miles. I use a separate trip meter.
My wife usually converts the roadbook for me into larger print and we do one for Andrew in braille.
You will be ok if you follow us, assuming we are going the right way. You will need your roadbook if we get separated.
Ta. How difficult can it be? Head west, if you come to the sea, you’ve gone too far.
‘10 BMW K1300GT
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
- arceye
The difficult part is the event running to time.
So you need to get to certain points on time. If you have a puncture or go the wrong way you can fall behind and end up with the cars which is a pain.
Air. Do we alter our pressures at stages or do we run with what we have? I’ve a small battery compressor, is that worth taking or are there air points en route? I’ve seen a list of spares recommended, is that worthwhile and is there anything else?
‘10 BMW K1300GT
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
- arceye
I usually let my pressure down to 15 psi at the end of the road run to Bridgewater. Then run with that all the way to the end. You should really pump them up after each section but the MT43's are quite rigid walls and seem to cope well.
I carry a small tool kit, spare plug, bulbs, belt ect. If anything major goes I will be calling recovery.
I’m running Continental TCX80 Twinduro, dunno what the sidewalls are like.
‘10 BMW K1300GT
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
‘85 Armstrong MT500
‘67 Norton P11
‘40 Norton 16H WD
Users browsing this forum: No registered users and 4 guests
