Moscow John's Engine Rebuild
Post by Minter » Fri May 10, 2013 12:07 pm
Moscow John shipped a 350 down to me to strip down and check out...
All good so far not a bad little motor.. its not seen many oil changes and basically needs a decoke.. Valves are still nicely seated and rings are almost like new.. Clutch and sprag clutch check this afternoon....
Ring end gap is almost like new..
Locating dowel for clutch case has a bit cracked off which made its way to the sump..
Re: Moscow John's Engine Rebuild
Post by Wirralman » Fri May 10, 2013 1:17 pm
Is this the engine that's been to Moscow/Moscow and UK/Nordkapp/Moscow/UK 2 up ?
Post by Minter » Fri May 10, 2013 2:47 pm
Wirralman wrote:Is this the engine that's been to Moscow/Moscow and UK/Nordkapp/Moscow/UK 2 up ?
Hi Eric, No this is out of Johns other bike.. It will be transplanted into the Moscow bike ready for the pyrenees, then the Moscow engine will be stripped and checked which should be interesting!
Post by bth2bth2 » Fri May 10, 2013 5:07 pm
at least you wont have to do the clutch :lol:
MONKEY
Post by MONKEY » Fri May 10, 2013 5:07 pm
Do you need a hand with the gasket this time? :lol:
Mt ,604
Mt 350
Armstrong 500
Post by Wirralman » Fri May 10, 2013 5:48 pm
Yes indeed. It could give a good indication of the weaker areas/ areas that wear or don't wear.
pupster
Post by pupster » Sat May 11, 2013 10:01 pm
....looking good Gary!.....it's going to feel like a new bike with this motor in it.....thanks for all your help.....
Post by Minter » Sun May 12, 2013 7:05 pm
Engine going back together nicely, hopefully tinypic will be working ok today!
Nope! no joy with tinypic today either!
Anyway sprag is as new, same as clutch all i had to do was file some very shallow grooves out of the basket..
The bottom end is all now done, just the topend to decoke and put back together tomorrow night..
Post by ZIP TIE » Sun May 12, 2013 7:07 pm
Minter wrote:Engine going back together nicely, hopefully tinypic will be working ok today!
Try Photobucket mate it's loads easier :)
http://photobucket.com/" onclick="window.open(this.href);return false;
pupster
Post by pupster » Sun May 12, 2013 8:12 pm
...it's going to feel like a dream machine.... :D
Users browsing this forum: No registered users and 12 guests
