Page 1 of 2
MT500 Some Assembly Required
Posted: Mon Jun 22, 2015 12:53 am
by SWRid3r
Needed a cheap dirt bike so i got someones MT500 failed project .
Cleaned it
Sprayed panels,engine,frame
Chucked the engine in
Linked enough stuff to run it but it wouldnt go. I also added new spark plug, air filter, oil filter, oil, battery. Fuel was blowing out the carb cuz timing was off by 1/4.
When it was running tried it round the garden. Very fun bike nearly went through the hedge. Front sprocket is 14t so nice acceleration.
Had a few issues with the build. The previous owner snap the key in the lock i had to pick it out. Electrics sucked i hate fault finding. Had gunk on the fuses so light didnt work. I wired the cut out switch wrong so the bike wouldnt cut out even with the key. Had to make a rear brake bar from a threaded m4 rod. My carb blew fuel cuz the timing was off.
Fun to make and learnt alot. My rear shock leaks so putting on a cheap ebay set then will be ready for mot. Took 7 days to paint 3 days to put together. Total cost £700 inc bike and delivery.
Re: MT500 Some Assembly Required
Posted: Mon Jun 22, 2015 6:37 am
by Franc
Very nice, I have a mt500 tank here without any dents, requires new paint but other than that looks ok if your looking to replace your one?
Posted: Mon Jun 22, 2015 9:43 am
by Club
Great job SWRID3R! ...and in such a short time. Has taken me ages to work out where everything goes when something comes in bits. Well done!
Posted: Mon Jun 22, 2015 11:50 am
by SWRid3r
Franc wrote:Very nice, I have a mt500 tank here without any dents, requires new paint but other than that looks ok if your looking to replace your one?
Dents add to the used and dirty look. I will be adding more dents when i start crashing off road.
Club wrote:Great job SWRID3R! ...and in such a short time. Has taken me ages to work out where everything goes when something comes in bits. Well done!
It came with the tech manual but most of the stuff i just found pictures online. There is a load of pics here http://www.qtg.co.uk/motorbike/files/mt500rebuild_Lila/" onclick="window.open(this.href);return false;.
Posted: Mon Jun 22, 2015 1:19 pm
by jamba
Well done, nice bike :)
Jamba
Posted: Mon Jun 22, 2015 7:32 pm
by Silver Fox
Lovely job. Just goes to show what you can do in limited time.
Posted: Mon Jun 22, 2015 8:01 pm
by Derrick
Looks good, great to see how it changed from what you had to start with.
Posted: Mon Jun 22, 2015 8:43 pm
by hounddog
Nice job .well done. Very satisfying seeing a project all coming together
Posted: Tue Jun 23, 2015 5:09 pm
by SWRid3r
Posted a vid of the bike on my channel https://www.youtube.com/watch?v=ksf1rsIjYNI
Posted: Tue Jun 30, 2015 12:14 am
by SWRid3r
Bike passed the mot. The headlight was hanging off when i got there but was lent the tools to fix it. Was my first proper ride and noticed oil is leaking at top of engine and the carb is overflowing.
