and it blew more than the dents out.petrolhead74 wrote: or do what I did and chuck it on a bomfire for a few minutes, no evidence of any petrol after that I can tell you.
Project 53 KL 04
Re: Project 53 KL 04
Past experience has tought me that this is rarely succesful, the last time I tried it I was watching intently to see the dents pop out and I noticed the tank moving on the bench.Green Goblin wrote:Yeah I agree about the fuel tanks. A mate suggested trying to get a couple of pound of air in the tank to see if the dents will pop out. Going back to the handling its when turning in it feels a bit strange so I'll check the head bearings out. I suppose the handle bars could be slightly bent as well.TDIPower wrote:Just noticed how much 'modification' that one previous owner has done to the fuel tanks!!! they only take 12ish litres normaly.... must be down to 8 litres now!!
It had started to spread across the width at the bottom, I ended up having to grind all the welds off to split the tank and knock it back into shape.
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
im not going to offer any ideas on getting the dents out... all mine would be H&S deathwishes so Ill keep them to myself!!
Surprisingly enough it worked a treat, the heat evaporated all petrol residue, the naked flames made sure the fumes were burnt off, and leaving the tank cap off and the petcock out prevented it from exploding, (you need containment for an explosion).ellrider wrote:and it blew more than the dents out.petrolhead74 wrote: or do what I did and chuck it on a bomfire for a few minutes, no evidence of any petrol after that I can tell you.
I must add it was not clever, but I was desperate to have the tank welded so I could use the bike to got to work on.
Im not planning on painting them just getting them legal. Im gonna concentrate on 53 KL 04 first. First jobs are check the steering and make sure she is straight, sort the speedo set front and rear pads and off for an MOT.ellrider wrote:Excellent, great pair of bikes, renovate no further, ride them as they are they look real nasty.
I'll try the length off wood first on the tank, before I try and blow it up
Stewart
- frenchy3
Hi,loosen off the axle clamp bolts and hold the front brake and pump the front end up and down a few times then nip them up and try to dee if the forks are still binding. Look at the top and bottom clamp and make sure they are in line and not twisted. Also remember this bike has probably been raced so the mechanics will possibly have put in the fork pre-load spacers making the front end harder. Loosen the top clamp allen screws and with a good fitting 6 point socket remove the fork caps and check for this and also check or replace the fork oil.(make sure the front end of the bike is supported with the front wheel off the ground or you will get a face full of springs and fork oil!)
The exhaust and mudguard orientation suggests the bike may have been dropped more than a few times and the rear frame section could be twisted. Remove some of the parts and do some measuring.
Steve
Steve
Where would you suggest measuring?frenchy3 wrote:The exhaust and mudguard orientation suggests the bike may have been dropped more than a few times and the rear frame section could be twisted. Remove some of the parts and do some measuring.
Steve
Stewart
Will these pre-load spacers be at the top of the forks?frenchy3 wrote: Also remember this bike has probably been raced so the mechanics will possibly have put in the fork pre-load spacers making the front end harder.
Steve
Stewart
- frenchy3
Hi,the preload spacers if fitted will be on the top of the fork springs directly under the caps. As for measuring the subframe i dont really have any ideas,it may be obvious to the eye if the damage is bad.
Steve.
Steve.
Hi frenchy thanks for the input. I've had a quick look at the frame but can't see any thing obvious. The other bike 53 KL 02 all looks straight and the exhaust is parrallel with the frame so I'll pop my wheels on it bleed the front brake swap the forks and give that one a go.
Stewart
Stewart
Users browsing this forum: No registered users and 105 guests
