Now where did I put that???
- Drifter
Re: Now where did I put that???
25kg aluminium oxide on fleebay Ă‚ÂŁ28.
MT350e
Ride safe / Ride MT
Ride safe / Ride MT
I finally got around to doing some work on this bike today. I pulled out my blasting cabinet, set up the compressor, gun filled with shot blast and my box full of bits. All happy. After de-rusting about 5 parts, I heard an odd noise coming from the garage. So I went in to investigate. There seemed to be an air leak coming from the moisture trap, but before I could disconnect it the regulator blew clean off it and hit the roof. I SH*T MYSELF...... So I think I may just get some wet n dry and rub it down by hand. Oh and a change of undies to.
At long last my compressor is up and running. I have spent 6 hours sand blasting my center stand. 6 Bloody hours... . And it ain't finnished yet. Was hoping it would take hours to do the whole bike.. This is going to take weeks... Better than daytime tele..
- ZIP TIE
have you got grit in your hair teeth and everywhere else as welll?
and in my undies and in the dogs bowl and the washing that was on the line, but don't tell the missusZIP TIE wrote: have you got grit in your hair teeth and everywhere else as welll?
I know your a perfectionist, but sandblasting your oxters is taking it a bit far Rusand in my undies
Where is the problem, does it not take the paint back to metal when you blast it? Are you using a high enough pressure or is it the paint or oxide that is hard to remove?rustybike wrote:I have spent 6 hours sand blasting my center stand. 6 Bloody hours...
The reason I ask is because a chap near me has a home made kit and it works very well. His box is made from old windows the sash type and he uses a hoover to extract and there is no problem with dust in his workshop.
BTW, how much of the media are you getting through?
Thanks,
I have an aldi 2.5hp compressor and spot blast gun. I have a home made cabinet that keeps the mess manageable. Never blasted anything before so am on a learning curve. May need a better gun or more powerfull comp. Any tips welcome. It does get down to the metal and ready for primer. I run the comp at 7 bar about 120 psi. But the pain is quite tough. Rust comes off in seconds.
Latest update on this slowly moving project.. After an ear bashing that nothing was getting done on the bike. I have had to bite the bullet and PAY someone to blast and paint my bits. Not looking foward to the bill but can't wait to see the results. Will post the pics when the parts come back.
Users browsing this forum: No registered users and 9 guests
