Engine stop
Engine stop
The engine can start without the key and it will not stop. Is there any easy solution. SWM xn350 but it should be nearly the same as MT 350
Re: Engine stop
It grounds a wire to the ignition unit to stop the engine. So either a broken wire to the switch from the chi box or from the switch to earth. Or the switch itself is not making contact.
Re: Engine stop
I will check that again, but to me the problem looks like it is in the cdi box. If so...is there any other solution .
Re: Engine stop
If it is the cdi, then its a replacement unit , I don't think you can repair them ,
