Aleman's Update Sep 09
Aleman
Re: Aleman's Update Sep 09
Post by Aleman » Sun Jan 10, 2010 10:09 pm
Me again,
Well, very nearly there.
I sorted the rear brake caliper. Seal problems. Doughnut here put a wrong small seal in. I put 2
"O" rings in opposed to the 1 then the complete round one without holes.
Thanks to the gent who put the caliper tutorial on the web as I was able to check the picture of
the contents and position Works ok now.
I have, it seems a very small leak in the fuel tank at the seat end, the one with the bullet holes
on it :lol:
The battery is now flat and unable to kickstart the beast into life so will cheat and charge up
the battery to push button start it, then kickstarbe easier.
I have a bit of private land (a car park) I can use to test ride it before I book the MOT.
As long as I can get the cash together and all goes well (pray) I should have it legal by this spring. Could not do it last year.
Watch this space!
Thanks for reading.
Regards,
K. ;)
Sserpent
Post by Sserpent » Mon Jan 11, 2010 10:38 pm
Hi Keith.
I've been enjoying reading about your build without saying anything, so I thought it was time to speak up. Brilliant job you've done there! I know I'd think twice before building a bike from scratch! Good luck getting it started. I mean this is a nice, "I'm sure it'll start easy" way. As opposed to a "Bloody good luck getting that bloody thing started mate!". :D And let me and my shins tell you. Electric start is NOT cheating. Especially when it's the first time and you still have a bit tweaking to do! :D
Neil
Aleman
Post by Aleman » Mon Jan 11, 2010 10:54 pm
Cheers for that, Neil.
Just been working on it this evening.
Battery charged (borrowed charger from the boss, at work not the misses :lol: )
Fired up straight away on the button then died but pumped more on the throttle and got
Persy running ok.
Took a test ride in the snow at the back of my place.
My house backs onto the sports ground next to the park so had to be double careful.
I noticed the lights kept going out then back on again.
It was the seat underneath connecting with the fuse box type thing...what's it called?
REMEDY: swapped the 2 nuts with countersunk screws which hold the connecting fork type
it that goes to the tank plus made sure I connected it to the rubber bit on the tank that bolts
to the frame.
Restarted it and jumped on the seat a few times. seems to have done the trick.
Will just need to start Persy up everyday now until I take it for an MOT.
Insurance quotes from Ă‚ÂŁ64 to Ă‚ÂŁ100 seem reasonable, fully comp.
I can legally ride it then to the test centre and back without a reg though only just down the road.
Should be up to date news early Feb.
Cheers,
Keith. :)
Post by Bunker » Mon Jan 11, 2010 11:37 pm
Good work Keith!
Daj
Post by Daj » Tue Jan 12, 2010 5:57 pm
Good work fella.
So close, almost there!
Daj
MT500e
Green Goblin
Post by Green Goblin » Tue Jan 12, 2010 8:41 pm
Well done Kieth, glad your getting there.
Stewart
UNK
Post by UNK » Tue Jan 12, 2010 9:12 pm
well done fella mine is still in a lot of pieces and the dragon is looming :roll:
Aleman
Post by Aleman » Thu Jan 28, 2010 10:49 pm
Sorry Chaps...me again.
Thought I'd give you another update, probably laugh at me too.
OK, where do I start.
Bike was running but pipes red again but everything else all ok except tatty looking loom
near cowl and tank.
I tided up the loom by wrapping the wires in old inner tube rubber(don't tell my son)
and used gaffer tape to bind, looks so much better.
Then; me thinks to readjust the valve clearances again, my feeler guages were in thou
and not mm. I set the outlet to 4 thou and did not touch the inlet valves.
MMMM. Sod did not want to start.
So what did I do? ...Did the fuel down port hole trick(previously changed the spark gap to 7mm)=Nothing.
Checked spark= Works.
Readjust both inlet and outlet clearances AGAIN to spec.
Rechecked Timing= Bang on.
Still not fireing up?????
Put in a new spark plug= BINGO!!!
Oh well at least I covered many options.
Verdict= me a plonker, should have tried the plug earlier, at least I know all is set as should
be...I think.
See link to exhaust for my query.
Thanks for reading.
Simon, if you're reading this then I hope your hip gets better...soon.
Cheers,
Keith. :D
Post by ZIP TIE » Thu Jan 28, 2010 11:30 pm
Are you sure :shock:
Post by ellrider » Fri Jan 29, 2010 12:51 am
Can see how a new plug might have helped :lol:
Users browsing this forum: No registered users and 131 guests
