Well sounds like it's running okay. Does the headlight flicker? If not you're probably in business. When I converted mine to 3 phase I noticed a but jump in charging power and the headlight is noticeably brighter.christos x wrote:OOPs! didn't see this till now...nothing disastrous happened fortunately. If something bad was going to happen how long would it take? Went out for hour and half ride and all seems well. But I will check it in the morning as its dark nowben wrote:Worth checking before riding off - run the engine and check you have 14.4V at the battery terminals before taking it out.
Otherwise if there is a problem then you're going to a) set the wiring loom on fire b) bust your magneto stator (£800 from Rotax) or c) boil the acid in your battery which will explode all over your leg or d) end up with a flat battery and no brake light e) break your new rectifier.
Re: What have you done to your bike today?
800 pound for a wotsit, they must be made out of meteorite rock by yangtze river dolphins, right thats another mod I won't be attempting
- christos x
I spoke too soon mate, checked the charge across the battery in the morning on your advice and bingo, the voltage across the battery when the spots are of is 18.4. That comes down to 13.5 when the spots are on so I'm now looking at finding a solution to controlling the high voltage via a relay (see my other thread in Problems section). Cheers for the heads up though cos the battery was bubbling away like a good un and the only thing that saved it on my test ride was the fact that I was running the bike with spots on constantlyben wrote:Well sounds like it's running okay. Does the headlight flicker? If not you're probably in business. When I converted mine to 3 phase I noticed a but jump in charging power and the headlight is noticeably brighter.christos x wrote:OOPs! didn't see this till now...nothing disastrous happened fortunately. If something bad was going to happen how long would it take? Went out for hour and half ride and all seems well. But I will check it in the morning as its dark nowben wrote:Worth checking before riding off - run the engine and check you have 14.4V at the battery terminals before taking it out.
Stripped all of the iron mugary off the back, actually made quite a difference to handling. planned a trip to squires bike cafe but never got there as my mates mz konked out, bluddy 2 stroke
Minivin wrote:.
minivin's text is still a small dot !!!!
cleaned the salty crud off mt and fitted a pair of gaiters to my rear shocks.they fit quite well and should protect my newish shocks .
made a b****cks of replacing my front sprocket by putting it on back to front
cleaned the sump guard and noticed the air intake fitting to the engine is loose, bugger
Fitted an Iridium DR8EIX-6681 spark plug. Has improved starting. I used to run one of these on my first bike and liked it. I hope to find once again that it runs better and last longer than the standard NGK plug.
Hi Mark is this on a 350 or the 500?Mark Hill wrote:Fitted an Iridium DR8EIX-6681 spark plug. Has improved starting. I used to run one of these on my first bike and liked it. I hope to find once again that it runs better and last longer than the standard NGK plug.
Got Persy cleaned and checked for the mot last week.
Dropped it off Tuesday morning and later picked it up with another pass.
They initially failed it on the light beam, apparently adjusted it then passed it with 2
advisories, 1 rubber mounts on handle bars with play (getting that sorted) and slight
discolouration on the headlamp.
Next order another speedometer cable and an oil pipe (slight leak).
Cheers!
Cheers!
Users browsing this forum: No registered users and 21 guests
