Web to GPS converter
Links websites of interests relating the the MT
Moderator: frenchy3
Apophis
Post by Apophis » Sat Oct 23, 2010 10:16 am
found this link on anouther forum thread
and have been playing with it good for finding Lanes and then waypointing them
you can then upload to your GPS
http://wtp2.appspot.com/wheresthepath.htm" onclick="window.open(this.href);return false;
frenchy3
Re: Web to GPS converter
Post by frenchy3 » Sat Oct 23, 2010 12:47 pm
Good find,i have an old garmin system Map 60c that works great with my os mapping and transfers easily via the usb cable but my brother has a Garmin map 62st and he has all sorts of problems and needs direct transfer of GPX files to his GPS which is treated by the computer as a mass storage device. This system looks like it would work and is also free after a donation to keep the site running. How do you transfer routes in GPX format? Many thanks in advance.
Steve.
Apophis
Post by Apophis » Sat Oct 23, 2010 1:16 pm
at the bottom of the OS map side there is a page up and page down by the bin
this will transfer direct to the GPS if connected
frenchy3
Post by frenchy3 » Sat Oct 23, 2010 7:16 pm
As simple as that! Much better than trying to configure Fugawi or memory map. Thanks.
Steve
Post by Derrick » Mon Oct 25, 2010 1:04 pm
Downloaded MadStu's route he recently posted and uploaded to this. Dead easy, and it overlays both OS and satellite pictures.
1997 HD MT350
2002 Honda Pan European 1300
MadStu
Post by MadStu » Mon Oct 25, 2010 1:28 pm
Seems to miss most of the waypoints out for me Derrick
HD MT604e - THE WUF
Armstrong MT405e - THE CNS
MadStu
Post by MadStu » Mon Oct 25, 2010 1:30 pm
I see now, it's reduced it from 640 route points to 99 :roll:
HD MT604e - THE WUF
Post by Derrick » Mon Oct 25, 2010 2:44 pm
MadStu wrote:Seems to miss most of the waypoints out for me Derrick
You got the advantage that you knew what should be there. ;)
MadStu wrote:I see now, it's reduced it from 640 route points to 99 :roll:
Looks like a lot of points missing :?:
1997 HD MT350
MadStu
Post by MadStu » Mon Oct 25, 2010 4:03 pm
Yeah, I think it must have a max number of waypoints for the gpx, so it culls it based on distance between the points, gradually increasing the distance until there's enough.
But gpx files aside, I've used this website in the past and it's a good tool.
HD MT604e - THE WUF
