Rotax 350 Engine.
ian
Rotax 350 Engine.
Post by ian » Mon May 18, 2020 6:37 am
While carring out an oil change I had an opportunity to check out some of the engineering, and materials used in construction. The valve train including roller cam followers and free rotating tappets seem very well designed and built for longevity. Looking up through the bottom of the crankcases reveals robustly forged crank and balance shaft/weight, full skirt piston may not be the fastest mover, but has huge bearing surfaces again for longevity, overall a very well built unit, very robust and long lived, and not limited in materials used by the accountants (unlike todays production) if there is an achilles heel to these engines please shout up as I can't find one. :geek:
Mt 350 (the Expensive one) :lol:
Re: Rotax 350 Engine.
Post by lardmarc » Mon May 18, 2020 7:22 am
Top end is the weakest part of the motor.
Gear box is bomb proof, piston/barrel holds up with regular oil changes.
Only the top ends let go unless you adjust constantly.
ian
Post by ian » Mon May 18, 2020 7:40 am
2 thou is tight, so I am assuming the alloy barrel is going to grow a bit with heat :roll: or are there opinions for running with larger clearences🤔 ian.
12royal
Post by 12royal » Mon May 18, 2020 8:12 am
Valve clearances must be set to manufactures spec no matter how awkward to do.
It doesn’t matter about the barrel expansion with heat because it won’t affect the valve clearances ( unlike pushrods )
Alan
nige
Post by nige » Mon May 18, 2020 8:19 am
The engines across the range, 350- 604 share many of the same part numbers. So, if it’s good for a 604 it’s over engineered for a 350!
ian
Post by ian » Mon May 18, 2020 8:43 am
That's reasuring to know, funny thing though, I was engineered to be 6 foot tall but turned out 5 foot 5 inches :( perhaps I will last a long time :lol: still the weakness is definatly the top end though. :roll: ian.
Post by lardmarc » Mon May 18, 2020 9:10 am
What he said. You'll get used to how little room there is to do the valves.
Running with larger clearances.
You'll go deaf.
Post by Laurence » Mon May 18, 2020 12:21 pm
Yep, killed that
Killed a couple of those as well..
Huge bearing surfaces
And yep destroyed a crank bearing too..
Damn, I’m sounding like Lard :shock: :lol:
#skippy1970
Post by #skippy1970 » Mon May 18, 2020 12:47 pm
Yep, killed that
You just need to leak a little fluid
And leave a nasty stain everywhere you go :D
If my brain was to get any smarter it would become self aware and take over my body
MT350 GL36AA
ian
Post by ian » Mon May 18, 2020 2:24 pm
Think I need a spare engine as I've done 935 kms on this one, from what I read it could let go at any moment. :o :o :lol:
Users browsing this forum: 12royal and 4 guests
