Rusty nuts
Franc
Rusty nuts
Post by Franc » Tue Mar 24, 2020 5:19 pm
Having bought an MT that was completely seized, I have set about occasionally tinkering with it when I'm bored, mainly just undoing, cleaning, lubricating and reassembling it bolt by bolt.
I occurred to me, when looking at your MT, if you had to strip it down, which bolt, or bolts, would you most dread tackling, and for what reason?
Re: Rusty nuts
Post by lardmarc » Tue Mar 24, 2020 6:03 pm
Exhaust studs. Nothing else seizes.
Re: Rusty nuts
Post by Wirralman » Tue Mar 24, 2020 6:10 pm
I well remember the first time I wanted to get access to the clutch.
Having removed the cambelt lower pulley I tried to undo the nut behind it having fitted crank locking bolt, engaged 1st gear and choked the rear wheel. I had the correct socket and fitted more and more extension bars, when they reached 3ft the nut eventually started to turn. I hadn't thought of loctite and the need for heat to soften it.
On the second one I did, the nut came off easily, but that had heat which was allowed so soak- the combination of soft loctite and a nut which would have expanded just a tad made a huge difference
I have never needed to remove the exhaust manifold, but that is a much feared job 😮
MTBrown
Re: Rusty nuts
Post by MTBrown » Tue Mar 24, 2020 7:29 pm
Swinging arm spindle - if rusted on to bearing journals then an absolute nightmare to extract. Been there with a Honda but not an MT!
Re: Rusty nuts
Post by Laurence » Tue Mar 24, 2020 8:36 pm
Exhaust studs.
And those cross head screws that hold the cover on the front brake master cylinder.... once rusty they round off in no time
#skippy1970
Re: Rusty nuts
Post by #skippy1970 » Wed Mar 25, 2020 10:50 am
Exhaust studs.
Try a JIS screwdriver they fit like a glove
No more mullered screw heads :D
If my brain was to get any smarter it would become self aware and take over my body
MT350 GL36AA
Re: Rusty nuts
Post by Wirralman » Wed Mar 25, 2020 12:05 pm
Exhaust studs.
I once tried a well fitting screw driver which had a hexagonal shaft. I soaked the master cylinder head screws with releasing fluid and put 6 inch spanner on the shaft but even with that leverage they wouldn't move.
Solution- a punch tapped into the screwhead, then angled so that the next blow turned the screw. New screws required, but at least I could get to the master cylinder and fit the parts from the refurb kit.
At the caliper end , new ball bearing required as the exposed side of that was rusty. I suspect that the brake fluid hadn't been changed for a very long time.
Rusty nuts, screws, ball bearings, all part of MT maintenance fun 😊
Re: Rusty nuts
Post by hounddog » Wed Mar 25, 2020 1:08 pm
I have undone most of the bolts and screws on mine over the years.
They are better on the MT than a lot of bikes I have had in the past . I was always using an impact driver on a Honda , rarely if ever on the MT
I have had to drill out , one screw joining the crankcase halves together , and the lower mounting bolt for gun box.
I have been lucky with exhaust studs , just use lots of penetrating oil over several days before trying to undo , maybe a bit of heat , and approach gently
The front sprocket nut can be quite tight to remove .
Rear sprocket bolts can also be troublesome , althogh mine were fine
#skippy1970
Re: Rusty nuts
Post by #skippy1970 » Wed Mar 25, 2020 1:13 pm
There are three types of cross type screw fixings
Philips
Pozidriv
JIS
If you use a Philips screwdriver on a say a jap carburettor it will try to cam out of the screw fixing
It is designed to do this
If you use a JIS screwdriver the difference felt is quite significant
This is why you see so many witness marks on carburettors :roll:
And why is that seized bolt always in the most inaccessible place :?
MT350 GL36AA
Pewter
Re: Rusty nuts
Post by Pewter » Wed Mar 25, 2020 6:10 pm
The allen head bolts holding the discs on are the worst fittings I’ve encountered. A good friend helped me by heating them with a welding gas torch before undoing them.
