Getting Started
DerekJD
Getting Started
Post by DerekJD » Sun Jul 07, 2019 9:30 am
I own a 1985 Mt500. I have mastered the cold start (just about) but the hot start usually ends up with having to bump start. What am I doing wrong?
Re: Getting Started
Post by Minter » Sun Jul 07, 2019 11:26 am
Hi Derek,
Firstly welcome to the forum, lots of good info on here if you use the search engine using key words..
As for hot starting just open the throttle slightly so a bit more oxygen is there to help ignition. This works for me but not many bikes dentical!
A good carb strip and clean works wonders just remember how it came apart. Valve clearances will be worth checking and so will the valve timing. The engines will run a tooth out but causes all sorts of issues..
Good luck, if you get stuck just give us a call at Sportax..
Gary
Sportax Racing
01952 850802
Force Motorcycles
Re: Getting Started
Post by Force Motorcycles » Mon Jul 08, 2019 8:02 am
Hi Derek,
Welcome to the forum!
We've got a blog post on this which you can find here.
Regards,
Force
Force Motorcycles - The World's Largest MT350 and MT500 Parts Dealer
The UK's Exclusive and Official ROTAX Parts Dealer
:arrow: Visit Our Online Store
:arrow: Follow Force Motorcycles on Facebook!
Re: Getting Started
Post by mt bandit » Mon Jul 08, 2019 6:12 pm
Hello Derek
if your on the original amal carb , you might want to consider a dellorto upgrade , it will most likely sort all your problems out
Africa twin 750
honda hornet 600 now sold :(
mt 500
mt560e
can am
divorce coming soon
