New mt.350
Will
New mt.350
Post by Will » Sun Nov 18, 2018 6:22 pm
Hi all ,have just returned to two wheels after a 25 year break .have just bought an MT350 which has stood since last spring .seems ok for age . started ok at point of sale .but not fired since unloading ,will check plug ,refresh fuel etc tomorrow.any suggestions that will save me swearing are most welcome.currently turns on the button with no hint of firing .off to search for wisdom on the forum now .my last ride was an A10 in the days before computers .so with the mt im moving forward in technology.thanks in advance for any tips.Will
Re: New mt.350
Post by hounddog » Sun Nov 18, 2018 6:34 pm
kill switch ? when looking at it you should see a picture of a horseshoe shape with a X through it (which isnt logical)
modern fuel goes stale - drain the carb and tank and put fresh in
Re: New mt.350
Post by Minter » Sun Nov 18, 2018 6:46 pm
Welcome to the forum Will,
Something simple no doubt just like Houndog says..
Ive been working on these MT's for over 30 years if you get really stuck!
Gary
Sportax Racing
01952 850802
Re: New mt.350
Post by twmtomos1 » Sun Nov 18, 2018 7:04 pm
the kill switch works opposite way ,good luck ,and welcome to the club
Re: New mt.350
Post by Wirralman » Sun Nov 18, 2018 7:15 pm
As Hounddog says, it's worth undoing the grub screw at the bottom of the carb so that you know you have fresh fuel ( assuming there IS fuel in the tank and it is fresh)
Fuel tap on ? Is enrichener ( lever on left of handlebar) turned FULLY on
Try kill switch in both positions. ( Don't get confused with the black out switch)
Try hooking up an additional battery in parallel ( If no additional battery available just charging may help. Batteries on MTs can die at the drop of a hat, fine first thing in the morning but like a dodo by noon
Clean all major electrical connectors ( The earth behind the horn is often corroded)
If it ran recently , there can't be much wrong
If it doesn't start after a few goes, have a cup of tea and come back to it ( NB This isn't for your well being. If attempts have made the plug wet it will dry out whilst you're slurping )
Next steps
Do you have a spark ? Unscrew the plug hold it so that the side touches the engine and press the starter, you should see a spark. If you have no spark/weak spark it will never fire
My bet ? A weak battery that isn't spinning the engine fast enough Kickstarting is possible and easy if everything is in good order and technique is good
PS When it does start, ride it straight away Coax it for the first 3 miles then reduce enrichener to half, ride another 2miles and knock it off completely NB clutch may feel notch until engine is hot
Mandatory to grin as in Cheshire Cat when it runs !
P.I.STAKER
Re: New mt.350
Post by P.I.STAKER » Sun Nov 18, 2018 8:13 pm
HI Will and welcome to the forum
good luck with the bike
https://sites.google.com/site/gvsparts/
ARMSTRONG MT500 1984
BMW R1100S
Force Motorcycles
Re: New mt.350
Post by Force Motorcycles » Mon Nov 19, 2018 8:45 am
Welcome to the forum Will :)
Force
Force Motorcycles - The World's Largest MT350 and MT500 Parts Dealer
The UK's Exclusive and Official ROTAX Parts Dealer
:arrow: Visit Our Online Store
:arrow: Follow Force Motorcycles on Facebook!
Will
Re: New mt.350
Post by Will » Sun Dec 16, 2018 12:21 pm
Thanks all for the help,
It was the kill switch .
Sorry I’ve not replied sooner I’m not good on computers and have only just found the replies.
I’ve been enjoying the bike and have been finding and solving small issues.iam at the moment changing oil ,renewing friction plates and a few other bits and pieces . Amongst which is the non return valve which was allowing the oil to drain back down .
Now the big question.
THERE IS ABOUT 1INCH OF OIL IN THE TIMING CASE
I know the none return valve was not working.but should I be looking for other issues or can I ignore this without dire consequences.?
Thanks in advance for your expertise.Will.
Re: New mt.350
Post by twmtomos1 » Sun Dec 16, 2018 2:31 pm
Hi Will ,do you mean the oil was in the cambelt cover or were the clutch plates are ? there shouldnt be any oil in the cambelt cover ,but you will get oil were the clutch plates are
Pewter
Re: New mt.350
Post by Pewter » Sun Dec 16, 2018 3:43 pm
Whilst there shouldn’t be any oil in the timing case where the belt is, there is a small drain hole in the bottom of the cover which can block up. If oil is getting into the case, possibly the cam and/or crank seal need changing. Clean it all out and run the engine with the cover off to see if you can seep where the oil is coming from.
