Introduction
Forum rules
Persevere - we're worth it!
Roadking
Introduction
Post by Roadking » Thu Nov 08, 2018 8:24 pm
Hello everyone, last year I started with refurbishing a MT 350 Harley from 1996 and got a license plate at the beginning of November this year. I think it is a very tough engine and my intention is to regularly withdraw into the woods and the countryside.
The carburetor of the engine seems to me out of order and so I am investigating how I can repair this.
Some technical advice from expert would be welcome and that is one of the reasons to join this club.
In the Netherlands there are not that many owners of a MT 350
Re: Introduction
Post by Wirralman » Thu Nov 08, 2018 9:02 pm
Welcome to the forum
The Keihin carb is fitted to the MT350 problems often found are
- clogged up jets and internal passages. Clean all jets and the hole through to the enrichener
. Remove jets and clean them. Use thin wire to clear passages You may have to remove a thin soft blanking plate . You may want to have the carb cleaned ultrasonically
- accelerator pump diaphram cracked or hard, replace it
- diaphram torn or weak, replace it
-rubber hoses to and from carb cracked or split
Top tip- replace standard No 40 pilot with a No 42
Drill larger hole to allow more air to flow.
Have a look through the forum Technical section or Google ' Keihin carbs' to find video clips
Cables dry out and stick, renew cables if the throttle doesn't open smoothly
The mixture is set weak, you can adjust it 1/8 turn at a time to find best setting
If airbox has had extra holes drilled in it, tape them up
Check cambelt is correctly set. The engine will run if one or even two teeth out, but it will not pull strongly
Once cleaned the standard carb is reliable. Some owners do fit other carbs
Have a good look through the forum Carburettor section
Good luck
gegdonnell
Re: Introduction
Post by gegdonnell » Thu Nov 08, 2018 10:56 pm
Hello and welcome, hope you manage to get your MT running OK.
Re: Introduction
Post by Minter » Fri Nov 09, 2018 1:23 am
Hi Roadking,
Welcome to the forum, hope you get your bike running properly soon, Your nearest Harley Davidson dealer should have carb spares in stock as they use the same carb on their big V twins.
We offer a dellorto carb replacement if you're after something a bit more conventional and responsive.
Sportax Racing
01952 850802
imthetourguy
Re: Introduction
Post by imthetourguy » Fri Nov 09, 2018 6:32 am
welcome!
you have a good supplier at https://www.gekra-motors.nl/webshop/
but the different suppliers you have here on the forum have a great reputation & from what I know much more active within the club.
either way, welcome to the forum!
Armstrong MT500 (Sand, MT350 front end)
Armstrong MT500 (in a box)
Armstrong MT500 (also in a box)
Flying Dutchman
Re: Introduction
Post by Flying Dutchman » Fri Nov 09, 2018 10:26 am
Welcome to the club, Roadking,
Nice to see a new Dutch MT-owner on this site. There are at least 11 active MT-owners in the Netherlands. Not bad for such a small country.
I buy most parts in the UK
Greetings,
Jan
*Harley X90
*Harley SX175
*Harley MT350
*Harley MT604
*Royal Enfield Bullet Diesel
Force Motorcycles
Re: Introduction
Post by Force Motorcycles » Sat Nov 10, 2018 9:53 am
Welcome to the forum! :D
Force
P.I.STAKER
Re: Introduction
Post by P.I.STAKER » Sun Nov 11, 2018 6:26 pm
Hi and welcome to the forum
good luck with your carb issues
https://sites.google.com/site/gvsparts/
ARMSTRONG MT500 1984
BMW R1100S
