Switchgear
Harrisg80
Switchgear
Post by Harrisg80 » Sun Sep 23, 2018 6:43 pm
Looking for working switchgear.especially the left side.
Thanks
Re: Switchgear
Post by lardmarc » Sun Sep 23, 2018 7:02 pm
Like this ?
I'm sure https://www.forcemotorcycles.com/ got some new left switch gear in even though I can't find them on the website.
Harrisg80
Re: Switchgear
Post by Harrisg80 » Sun Sep 23, 2018 9:28 pm
Yes that the part but I want a used one. New will be too expensive.
I did look on the usual sites but found nothing.
The Harris uses Magura,but the mt version looks similar. I have the headlight flasher and side light but no main/did hence suspect the switch.
Re: Switchgear
Post by lardmarc » Sun Sep 23, 2018 9:38 pm
Suspect the switch.
Undo the tiny little screw underneath and pop it out for a look. I've had solder break at the cable, fiddly soldering it back together.
Also check the fuse, it might look OK but minute break in it and it won't work.
Harrisg80
Re: Switchgear
Post by Harrisg80 » Sun Sep 23, 2018 9:43 pm
Thanks. Done both but no problem. The only thing I found was a bad earth above the engine. It did not sort the problem.
Also too a direct feed from battery to switch whilst apart..nothing..yet the flasher works! Odd!!
Force Motorcycles
Re: Switchgear
Post by Force Motorcycles » Mon Sep 24, 2018 8:19 am
Hi,
We might have a solution for this - drop us an email and we'll see if we can help.
Force
Harrisg80
Re: Switchgear
Post by Harrisg80 » Mon Sep 24, 2018 2:13 pm
Thanks for the suggestions and support.
I have resolved the problem internal break in the loom found by taking live feeds from each feed until the faulty wire was traced.
