New member
Shane board
New member
Post by Shane board » Sun Apr 15, 2018 3:11 pm
Hi I’m Shane I’ve just got Armstrong mt500 that needs some work but it should be good fun if I can start it ha ha!! I’ve started it 3 times so far but I will find the best way
Priest
Re: New member
Post by Priest » Sun Apr 15, 2018 4:02 pm
Welcome on board shane
Exemplo Ducemus
Force Motorcycles
Re: New member
Post by Force Motorcycles » Sun Apr 15, 2018 4:03 pm
Welcome to the forum, Shane!
Force
Force Motorcycles - The World's Largest MT350 and MT500 Parts Dealer
The UK's Exclusive and Official ROTAX Parts Dealer
:arrow: Visit Our Online Store
:arrow: Follow Force Motorcycles on Facebook!
Derrick
Re: New member
Post by Derrick » Sun Apr 15, 2018 6:39 pm
Welcome Shane, I'm sure you will soon be an expert at starting your MT. a couple of hints are to make sure no one is watching and to make sure you are not in a hurry to get somewhere.The only think worse than those is to boast that it starts 1st kick.
You will find plenty of info here. There are few issues that have not been discussed in depth, including kick-starting an MT.
1997 HD MT350
2002 Honda Pan European 1300
P.I.STAKER
Re: New member
Post by P.I.STAKER » Mon Apr 16, 2018 9:10 pm
Hi Shane and welcome to the forum
Its just a matter of finding the right technique
https://sites.google.com/site/gvsparts/
ARMSTRONG MT500 1984
BMW R1100S
Shane board
Re: Progress
Post by Shane board » Mon Apr 16, 2018 11:20 pm
Got the old girl started tonight after doing the valve clearances and playing with dellorto 34 carb still easier to start my triumph tr6c.but it’s running better and starts up after a couple of kicks,loads to do on it clutch heavy as hell supposed to have new clutch plates in it.thanks for everybody’s replies
Re: New member
Post by Minter » Tue Apr 17, 2018 6:05 am
Hi Shane,
Welcome to the forum - great choice in MT! Glad you've sussed the starting. The delly carb is the best carb for these engines.
Might be worth checking your clutch over - a new cable routed correctly often works wonders, but I have come across engines with small valve springs for clutch springs which you need 2 hands to pull in the clutch! Not the best mod in the world ive come across! You should be able to operate the clutch with one finger!
Gary
Sportax Racing
Re: New member
Post by Wirralman » Tue Apr 17, 2018 6:16 am
Good to hear that you are making progress The clutch will possibly benefit from new springs Check the length and tolerance in the manual.
You can buy replacement springs from the usual MT suppliers or get them made up locally to your specification If you consider the cost of the springs plus postage, there is little difference in price . I had them made 20% lighter on one MT with no adverse effects
You may also wish to fit a new clutch cable ( they snap at the handlebar end with no warning), leaving, as a spare, your old cable taped up and protected against the weather.
Clutch lever mechanisms can also wear, they look ok but you can notice a difference if you fit a new lever and pivot bolt
Obvious really but it's worth checking that you have the right number of clutch friction plates and steels (some owners have discovered to their horror that some have gone awol or are the wrong thickness) As for the plates themselves, the usual tolerance checks of course
NB This is the Welcome section of the forum, and is auto-erased after a short time Post any technical queries in the appropriate section and the question/ responses are preserved
A post in the Wanted section is worthwhile, someone may have spares surplus to requirements
Re: New member
Post by twmtomos1 » Tue Apr 17, 2018 7:17 am
welcome to the club,i had a really heavy clutch turned out to be the cable,good luck
Shane board
Made a bit more progress tonight
Post by Shane board » Tue Apr 17, 2018 8:23 pm
Thanks for your helpful replies.ive stared it up tonight and took for a short ride up the field great fun and feels quite torquey so after picking it up last Friday I’m well pleased with the progress,its had new friction plate apparently but I will take it apart and check the spring and cable mechanism.i think the release bearing is making a noise because when you pull the clutch in it quiets down is this correct thanks again!
