Just Joined
John Rawlinson
Just Joined
Post by John Rawlinson » Thu Apr 05, 2018 6:22 pm
I have just bought a HD MT350 from the Matlock area and brought it back to Nottingham.As is usual for me, ran great when I went to see it and now runs erratically. Going to try cleaning carb out, so hoping to find out how to go about it.
Re: Just Joined
Post by Wirralman » Thu Apr 05, 2018 6:40 pm
Welcome to the forum
Rust and rubbish in the fuel system is quite common, best to chase through from tank, fuel lines, fuel tap, anti-tilt valve ( if fitted), and carb ( many are ultrasonically cleaned)
Personally I favour sealing the tank with POR 15 as well If you remove the tap you can also see if you have any reserve at all ( many tubes are shorter than they were when originally fitted)
Re: Just Joined
Post by hounddog » Fri Apr 06, 2018 4:42 am
Hi and welcome to the forum , hope you get it sorted ,
check if tank is breathing as well
Re: Just Joined
Post by twmtomos1 » Fri Apr 06, 2018 7:45 am
Welcome to the club ,check the simple things first ,the intake rubber from carb to engine they can go hard and split also has the choke returned , post what you find good luck
Force Motorcycles
Re: Just Joined
Post by Force Motorcycles » Fri Apr 06, 2018 8:00 am
Welcome to the forum John!
Force
Force Motorcycles - The World's Largest MT350 and MT500 Parts Dealer
The UK's Exclusive and Official ROTAX Parts Dealer
:arrow: Visit Our Online Store
:arrow: Follow Force Motorcycles on Facebook!
12royal
Re: Just Joined
Post by 12royal » Fri Apr 06, 2018 2:19 pm
Hi John and welcome to the forum :)
I live in Long Eaton, not too far from you. If you need any help send me a pm.
Good luck with sorting your bike.
Alan.
Re: Just Joined
Post by Minter » Mon Apr 09, 2018 4:33 pm
Welcome to the forum John.
How's the erratic running? Have you solved it yet?
Gary
Sportax Racing
