Web to GPS converter
Moderator: frenchy3
found this link on anouther forum thread
and have been playing with it good for finding Lanes and then waypointing them
you can then upload to your GPS
http://wtp2.appspot.com/wheresthepath.htm" onclick="window.open(this.href);return false;
- frenchy3
Re: Web to GPS converter
Good find,i have an old garmin system Map 60c that works great with my os mapping and transfers easily via the usb cable but my brother has a Garmin map 62st and he has all sorts of problems and needs direct transfer of GPX files to his GPS which is treated by the computer as a mass storage device. This system looks like it would work and is also free after a donation to keep the site running. How do you transfer routes in GPX format? Many thanks in advance.
Steve.
Steve.
MT 350 1996 The Albatross
at the bottom of the OS map side there is a page up and page down by the bin
this will transfer direct to the GPS if connected
- frenchy3
As simple as that! Much better than trying to configure Fugawi or memory map. Thanks.
Steve
Steve
Downloaded MadStu's route he recently posted and uploaded to this. Dead easy, and it overlays both OS and satellite pictures.
1997 HD MT350
2002 Honda Pan European 1300
Seems to miss most of the waypoints out for me Derrick
HD MT604e - THE WUF
Armstrong MT405e - THE CNS
I see now, it's reduced it from 640 route points to 99
HD MT604e - THE WUF
You got the advantage that you knew what should be there.MadStu wrote:Seems to miss most of the waypoints out for me Derrick
Looks like a lot of points missingMadStu wrote:I see now, it's reduced it from 640 route points to 99
1997 HD MT350
Yeah, I think it must have a max number of waypoints for the gpx, so it culls it based on distance between the points, gradually increasing the distance until there's enough.
But gpx files aside, I've used this website in the past and it's a good tool.
HD MT604e - THE WUF
