Dellorto Carburettor Upgrades
Post by Minter » Mon Oct 15, 2018 10:46 am
The long awaited Dellorto Carb kits for MT350's and 405cc variants are now back in stock..
https://sportaxracing.co.uk/shop/dellor ... hf-34-kit/
We also have upgrades for 504, 555 and 560 Rotax Engines
https://sportaxracing.co.uk/shop/mikuni ... hf-36-kit/
And 604 & 636 versions
https://sportaxracing.co.uk/shop/mikuni ... hm-40-kit/
All kits have been proven and set up on a dyno with significant improvments in power and performance over original carburettors.
Re: Dellorto Carburettor Upgrades
Post by mt bandit » Mon Oct 15, 2018 6:42 pm
I have to say i bought the 36mm off gary for my 500 .
And I think it's an amazing upgrade .much better than the mikuni .as for the amal. Well .
Cheers Gary. It started first go .very responsive .
Very happy
Post by Minter » Mon Oct 15, 2018 9:33 pm
mt bandit wrote: ↑
Very happy
Cheers Mick glad youve got it fitted.
yeti341
Post by yeti341 » Tue Oct 16, 2018 3:50 pm
Fitted one to my 405 amazing the difference it made .
robandrewjones
Post by robandrewjones » Mon Mar 25, 2019 8:55 pm
I've just recently had a PHF34 fitted to my MT350.
Absolutely the best modification for the '350 - smooth, consistent, better starting and much better fuel economy than the stock carb.
If you don't already have one, get one bought!
Thanks to Gary at Sportax for answering all my questions and for the super fast postage.
Post by Wirralman » Mon Mar 25, 2019 10:21 pm
robandrewjones wrote: ↑
I never had any problem starting my MT350s fitted with the standard carb. That said, I did take carbs apart, fitted #42 pilot jets, fitted new accelerator pump diaphrams AND cleaned out the enrichener drilling. As for fuel economy long distance about 70mpg, normal riding around 66ish and off road low 60s.
The Keihin carb is used with different needles for a range of engines. I think the standard MT350 was fitted with the second out of a range of six fitted. In military trim it was set quite lean and many civilian owners removed the anti-tampering plug to richen the mixture. A high performance carb it is not
Gary is THE MT tuning guru ( he can ride a bit too !)
Tony Martin
Post by Tony Martin » Sat May 30, 2020 6:55 am
Hello new to MT 500 s , I have a Del Orto carburettor on my 500 not sure which one
Think it’s been played with could I ask
What size main jet is standard and how many turns is required for the air screw
I may need to buy some spares for it
Many thanks Tony
ian
Post by ian » Sat May 30, 2020 7:06 am
Delorto 34mm, Sportax exhaust system, and an opened airbox have all made noticable power gains to my mt350 which I think is about as good as it gets while running a standard barrel and piston, thanks Gary :D ian.
Mt 350 (the Expensive one) :lol:
