Loss of power
Forum rules
Persevere - we're worth it!
Matthewrquinn
Loss of power
Post by Matthewrquinn » Wed Jan 10, 2018 10:09 pm
Hi
I’m trying to figure out why my 350 loses power. It’s a 1996, just last week I replaced the (original) battery and also the rubber tube from the carb, which had split magnificently. Starts like a dream, ticks over and then when I put it in gear and set off it just dies. I take it over fields to go pigeon shooting and today it was about double the weight in mud, and it died on me when I got back on the tarmac and I had to push it most of the way home.
Done 6,500 Miles, it was a former “blood bike” running from medic station to helicopters with a Red Cross on the tank (I know this as an old RLC colleague of mine was the one that “demobbed” it), somit probably never got out of 2nd gear until I got it.
I’m sad and confused about this. Any help?
Re: Loss of power
Post by arceye » Wed Jan 10, 2018 10:17 pm
Fuel cap not venting ?
MT 405
Re: Loss of power
Post by Minter » Wed Jan 10, 2018 10:40 pm
Carb diaphragm rubber??
Re: Loss of power
Post by deadgrass. » Thu Jan 11, 2018 8:16 am
old fuel?
Re: Loss of power
Post by hounddog » Thu Jan 11, 2018 9:50 am
or
cambelt jumped a tooth
needle in carb come loose
Choke cable stuck open
A brake jammed on
Matthewrquinn
Re: Loss of power
Post by Matthewrquinn » Mon Jan 15, 2018 4:32 pm
Thanks all. I’ve a new carb rubber so I can rule that out, I hope. I do have a tendency to screw the fuel cap really tightly, my other bike is a Fatboy and they leak if it’s not screwed massively tight, so I’ll check that first. I’m a fan of trying the simple things first.
Cheers for the advice. Happy and safe riding all.
Pewter
Re: Loss of power
Post by Pewter » Tue Jan 16, 2018 7:09 pm
Have you checked the carb diaphragm rubber, under the carb top plate, as suggested by Minter?
Users browsing this forum: Harrisg80 and 0 guests
