ron woods rotax
motorhead
ron woods rotax
Post by motorhead » Mon Oct 15, 2018 2:30 pm
I have a ron woods frame mt 350 rotax flat track frame going to ride on the road motor is together but need help hooking up coil and voltage regulator color of wires would be helpful. which color wire comes from the stator and side cover and where they go.
Re: ron woods rotax
Post by Minter » Mon Oct 15, 2018 2:54 pm
Hi Motorhead,
Welcome to the forum,
We have worked on a few Wood motors which have found their way to UK..
If you click on our club shop link below you will see a link to all the documents every produced for the Rotax engine.
The info you need will be in there.
If you need more power for your 348 engine we do 405cc big bore kits which almost doubles the power output.
Hope that all helps
Sportax Racing
0044 1952 850802
motorhead
Re: ron woods rotax
Post by motorhead » Mon Oct 15, 2018 3:11 pm
I need a wiring schematic for the voltage regulator and coil and ignition system with the colors of the wires shown mt 350 rotax
Re: ron woods rotax
Post by Minter » Mon Oct 15, 2018 3:30 pm
motorhead wrote: ↑
Yep, its on the link..
