Headlamp Booster Kits
Speedshop
Post by Speedshop » Thu Jan 29, 2015 10:46 am
.....back in stock :D
http://www.rexs-speedshop.com/epages/es ... iewProduct" onclick="window.open(this.href);return false;
Classic Performance
Tolle09
Re: Headlamp Booster Kits
Post by Tolle09 » Thu Jan 29, 2015 6:23 pm
I got one a bit back, big improvement over stock 'tea light', can actually see where you're going
Post by arceye » Thu Jan 29, 2015 7:45 pm
Oh good, hope I am not too late. :D
MT 405
Post by TDIPower » Thu Jan 29, 2015 10:23 pm
They certainly are well made, the wish I have is that the power lead had been a bit longer between the unit and the fuse. I wanted to remove the fuse and use the spare trip on the top of the airbox, I could cut it, extend and heatshrink it. Haven't decided yet
Speedshop
Post by Speedshop » Sat Jan 31, 2015 10:34 am
We can do that for you if you send it back
Classic Performance
Post by TDIPower » Sat Jan 31, 2015 8:54 pm
Cheers for the offer, it's not worth the bother and postage each way. Ill sort it one way or the other, I have a reasonable selection of heat shrink so I may just extend it myself.
frenchy3
Post by frenchy3 » Sun Feb 01, 2015 9:52 am
Very good kit,of course you can do it cheaper but all the right connections are there without butchering your loom,it has a fully sealed relay box,good instructions on fitting and of course it does what it says on the tin a good improvement on the standard set up especially with the BA20D halogen bulb fitted. If you look at the light switch contacts and realise why relays are the best way forward.Highly recommended.
Steve.
Max5400
Post by Max5400 » Wed Jan 27, 2016 10:47 pm
Easy to fit big improvement many thanks
Post by TDIPower » Thu Jan 28, 2016 8:22 pm
Pity production got pulled.
One upgrade would have been to have a side light connection so when the bulb goes you can still have the side light (LED version) on which is what I have done.
#skippy1970
Post by #skippy1970 » Thu Jan 28, 2016 8:29 pm
TDIPower wrote:Pity production got pulled.
I've had a look at the shop and there is stock , so I presume production is still on
Good idea about the side light :D
If my brain was to get any smarter it would become self aware and take over my body
MT350 GL36AA
