mt bearings
P.I.STAKER
mt bearings
Post by P.I.STAKER » Sun Feb 10, 2013 10:50 pm
hi
After quite a bit of research and with the help of forum members , I have now sourced most of the bearings that fit our mt’s
These are all direct replacement parts all used by major manufacturers they are just as good quality as the original items possibly better.
Having now bought in bulk and received a great discount, I will be passing on these savings to members only.
The list is probably not comprehensive, so more will be added; please let me know if you think any are missing, or need to be added.
All bearings are skf or similar quality.
Please pm me for prices, these will be dependant on quantities required.
Very welcome to ask about any type of bearings required for other projects.
All prices are approx.
Mt350 wheel bearings
Front wheel x 2 £11.50
Rear wheel x 4 £21.50
Rear hub x 3 £15.00
Mt500 wheel bearings
Rear wheel bearings hub x 4 £21.50
Brake drum x 2 £10.00
Front wheel bearings x 2 £11.50
Engine bearings
Mainshaft 232-092
Camshaft bearing 932-432
Cambelt tensioner 932-037 £6.95
Mainshaft clutchside 932-033
Bearing clutch shaft 932-430
Crank bearings 832-235 quantity 2
Balance shaft bearings 932-095 quantity 2
Camshaft closed needle roller bearing BK2212 approx £9.50
Clutch bearing
Clutch bearing 932-815
Ball bearing clutch 232-400
Headstock bearings
quantity x 2 £19.50
Swing arm bearing kit
Needle roller bearings x 2 & 8 x o-rings £12.75
Mod to cambelt idler 3 x 638 bearings, either zz or 2rs your choice £9.50
ARMSTRONG MT500 1984
BMW R1100S
P.I.STAKER
Re: mt bearings
Post by P.I.STAKER » Fri Jan 24, 2014 7:51 pm
just a bit of an update
there is a small price increase from the above list, as this list is a year old
should also add, now have the rear shock absorber spherical bearings
thanks
george
BMW R1100S
P.I.STAKER
Re: mt bearings
Post by P.I.STAKER » Fri Aug 14, 2015 6:57 pm
BEARING SALE
secured a bulk bearing purchase
happy to pass on the discounts
front wheel bearings (pair) £6.75 delivered
rear wheel bearings (pair) £7.75 delivered
all bearings skf, fag or similiar
all other bearings available
please ask even if its not on the list
Regards
george
P.I.STAKER
Re: mt bearings
Post by P.I.STAKER » Tue Feb 23, 2016 4:15 pm
FREE
i have 5 x sets of front wheel bearings(10 bearings)
they are NSK, direct equivalent to 2rs bearings
similar quality to SKF , do not hesitate to use myself
1 x set per member
all that is asked is a donation is made to the club, will leave this to good will
pm me if required
cheers
george
BMW R1100S
Re: mt bearings
Post by appyarry » Thu Feb 25, 2016 9:14 am
PM'd :-)
MT 604e :-)
Re: mt bearings
Post by mt bandit » Thu Feb 25, 2016 9:39 am
pm'd
Africa twin 750
honda hornet 600 now sold :(
mt 500
mt560e
can am
divorce coming soon
P.I.STAKER
Re: mt bearings
Post by P.I.STAKER » Thu Feb 25, 2016 1:41 pm
no pm received, let me know please
also;
1 x set left, anyone?
cheers
george
BMW R1100S
P.I.STAKER
Re: mt bearings
Post by P.I.STAKER » Fri Mar 11, 2016 9:24 pm
all gone and sent
thanks lads, please dont forget your donations
George
BMW R1100S
P.I.STAKER
Re: mt bearings
Post by P.I.STAKER » Sun Jul 17, 2016 9:25 pm
hi
updated this thread, link to photobucket below.
not all on there yet, but still work in progress.
will also update price list.
http://s738.photobucket.com/user/p-i-st ... 20BEARINGS
cheers
George
BMW R1100S
