Georges MT parts
P.I.STAKER
Re: Georges MT parts
Post by P.I.STAKER » Fri Jan 30, 2015 10:21 am
another item requested
ITEM 111
MT500 Speedo drive gear thrust washers x 2
direct replacement
service manual chapter 15, items 23&25
£5.75 delivered
ARMSTRONG MT500 1984
BMW R1100S
WJP
Post by WJP » Tue Feb 10, 2015 11:22 am
Having had a number of attempts at stopping the side stand wagging like a dogs tail, I asked George to make up some side stand bushes to a drawing I provided. Pleased to report that they work really well with no more tail wagging the dog!
Cleaned out the powder coat with an old 1/2inch reamer (50p at a boot sale) and the new bushes slip in no problems. Side stand movement at the rubber stop is 1mm cf over 50mm with the old worn bushes.
Many thanks George
Image Image
Image Image
P.I.STAKER
Post by P.I.STAKER » Tue Feb 10, 2015 3:29 pm
thanks for the pics will
i know it took a few attempts, but hopefully we have the correct option now.
thanks for testing and for the patience
regards
george
BMW R1100S
Aleman
Post by Aleman » Fri Feb 20, 2015 4:23 pm
Are there replacements for the "screw" that adjusts the clutch play at the casing end behind the right hand black plastic screw in oil cap/seal?
Mine sheared when I was adjusting. Whoops!!!
Post by ZIP TIE » Fri Feb 20, 2015 4:30 pm
Aleman wrote:Are there replacements for the "screw" that adjusts the clutch play at the casing end behind the right hand black plastic screw in oil cap/seal?
By sheared do you mean you snapped one of the bits to the side of the slot off?
If this is the case get a normal high tensile hex bolt with the right thread, saw the hex off and cut a slot in it, don't use stainless as it snots over and wears leaving a mushroomed head
Post by Minter » Fri Feb 20, 2015 6:45 pm
Why not fit the proper part.. They are £3.30 in the Sportax shop! Search 240 310
Hope that helps..
P.I.STAKER
Post by P.I.STAKER » Fri Aug 14, 2015 6:51 pm
some more requested items
ITEM 112
Kickstart spring and drive installer
tool to aid in the fitting
£19.75 delivered
ITEM 113
MT500 rear wheel torque adapters x 2
allows a conventional torque wrench to be used to torque up the rear wheel nuts
£19.75 delivered
ITEM 114
Crankshaft pulley stainless nut and spring washer
£5.95 delivered
ITEM 115
MT350 brake caliper high tensile caphead bolts, set of 4
these secure the 2 halves of the caliper together
also available in stainless
£4.35 delivered
ITEM 116
Refurbed original exhaust silenecer
repaired to a very high standard
either on an exchange basis or straight sale depending on availability
from £70 delivered
ITEM 118
MT500 fuel cap seal
originals no long available
manufactured from a dual compound viton
been told they should last forever
£9.75 delivered
will update photos later, as wont let me at the moment
P.I.STAKER
Post by P.I.STAKER » Mon Aug 24, 2015 7:03 pm
another item recently requested
ITEM 118
MT350 rear wheel spider housing bearing spacer
manufactured from stainless
comm. parts list, plate 7 - item 43
£6.85 delivered
will update photos as and when i can
P.I.STAKER
Post by P.I.STAKER » Sun Aug 30, 2015 7:31 pm
here!
Post by Mr Shiney » Sun Aug 30, 2015 7:44 pm
Brilliant work George. Your endless line of upgrades is terrific. Better than OEM.
