Georges MT parts
P.I.STAKER
Georges MT parts
Post by P.I.STAKER » Thu Jan 19, 2012 7:18 pm
I have run this by the admin team.
Having lost the use of a decent lathe at work, I was struggling to find anywhere to have items manufactured. I decided to buy a smaller lathe and have finally set up a small workshop in my shed.
While I have been working my way through my own mt500 restoration I have been measuring, drawing and manufacturing some of my own parts from stainless steel.
List and photos to follow.
Some of the parts include;
Front wheel bearing spacer, both inner and outer
Rear wheel and hub inner bearing spacers.
Rear wheel L/H outer spacer (can be split in 2 for easier installation)
Exhaust header clamp spacers
Footpeg spring spacers
Foot brake lever bush
Rear brake rod, cam and knurled adjuster
Binnacle/instrument cluster bush inserts
Handle bar clamp bush inserts
Side stand olite bushes and insert
Much prefer stainless, no rust, no painting and looks better generally.
More to follow, like looking into making some bar ends for open grips, basically just to hide the holes in the end of the bars.
Also made up some bearing installers from ally, list and photos to follow.
Members can also request any other parts they require, will have to send a drawing with accurate dimensions, or send me a pattern.
At the moment this will be non-interference items, such as spacers, inserts etc
I am now in a position to open this up to club members, if anyone is interested?
Prices will be cost including p&p plus a small amount for any extras, which will include a donation to the club for all items.
Just to add, this will not be a quick service, i.e. the next day, it will be as and when work/time allows. Usually within a couple of weeks.
If I can help in anyway please pm me.
ARMSTRONG MT500 1984
BMW R1100S
P.I.STAKER
Re: lathe work
Post by P.I.STAKER » Thu Jan 19, 2012 7:35 pm
ITEM 1
MT500
Rear brake operating rod / knurled adjuster & trunion.
St/st rear brake rod, cam and knurled adjuster. All parts are stainless, with st/st rose joint and fittings to fit to brake pedal. The stainless rose joint stops the hole being elongated, as this sometimes happens with the old mild steel rod.
(Service manual chapter 14 items 51, 52, 53)
£20 inc UK P&P
ITEM 2
MT500 / POSSIBLY MT350 ASWELL
Replacement foot peg spacer/bush, that go inside the spring.
Will be made from stainless x 2
(service manual chapter 8. item 27)
£4.50 (pair) inc UK P&P
ITEM 3
MT500 REAR WHEEL R/H SPACER
(service manual chapter 14 item 48)
£4.50 inc UK P&P
ITEM 4
MT500/ 350 HANDLEBAR CLAMP MOUNTING SLEEVE/INSERT/BUSH X 2
replacement item made from stainless
(sevice manual chapter 11 item 22)
£4.50 inc UK P&P
ITEM 5
MT500 FRONT WHEEL HUB INNER SPACER
fits between front wheel bearings
replacement made from stainless
(service manual chapter 15 item 13)
£4.50 inc UK P&P
ITEM 6
Swing arm bearing installer/remover - £5
swing arm needle roller bearing installer/remover. manufactured from ally to stop damage to bearings
£5 inc UK P&P
ITEM 7
main steering stem bolt washer - £3.50
top yoke main steering stem bolt washer. replacement manufactured from stainless.
(service manual chapter 11 item 9)
£3.50 inc UK P&P
ITEM 8
rear wheel l/h spacer, split or 1 piece.
(sevice manual chapter14 item 15)
£13.50 inc UK P&P
ITEM 9
rear wheel hub spacer
(service manual chapter 14 item 18)
£6.50 inc UK P&P
ITEM 10
rear brake drum inner bearing spacer
(sevice manual chapter 14 item 23)
£5.00 inc UK P&P
ITEM 11
instrument/dash/console mounting bush inserts x 2
(service manual chapter 13 item 71)
£4.40 inc UK P&P
ITEM 12
front and rear indicator fittings x 4
replacements are stainless
2 x front nuts are machined to 7mm width to match the originals
2 x rears either drilled domed or nylocs
includes washers
(service manual chapter 7 items 31&47)
£3.00 inc UK P&P
ITEM 13
2 x stainless fittings to blank holes in wheel rims if rim locks are removed/not used
complete with seals,washers and domed nuts
(service manual chapter 14&15 items 1-3)
£1.75 inc UK P&P
Item 14
front wheel outer spindle spacer
replacement manufactured from stainless steel
i believe this fits the 350 aswell
(sevice manual chapter 15 item 44)
£4.50 inc UK P&P
Item 15
2 x stainless steel crank locking bolts
£1.75 inc UK P&P
Item 16
2 x swing arm inserts
manufactured from ally to hold swinging arm in place whilst engine/spindle is removed
£6.00 inc UK P&P
ITEM 17
swinging arm spindle stainless fittings
2 x m14 nylocs,washers & st/st grease nipple (spindle not included)
(sevice manual chapter 10 items 28,35 & 36)
£5.50 inc UK P&P
BMW R1100S
P.I.STAKER
lathe work
Post by P.I.STAKER » Thu Jan 19, 2012 7:36 pm
ITEM 18
mt500 rear brake drum / 6004 bearing installer
manufactured from alluminium, bearing can either be pressed or knocked in
£5.00 inc UK P&P
ITEM 19
mt500 front brake/plate/torque arm & brake arm stainless steel fittings kit
includes all fittings that attache to the above
(service manual chapter 15 items 17,18,21,26,27,29,30,31,34,36)
£6.00 inc UK P&P
ITEM 20
MT500 centre stand& chain slipper stainless steel fittings kit
2 x bolts, spring and flat washers and st/st grease nipple
(service manual chapter 8 items 31,32,33, 36 & 37)
£4.50 inc UK P&P
ITEM 21
Rear wheel bearing/6203 bearing installer
bearings can be pressed or knocked in
£5.00 inc UK P&P
ITEM 22
MT500 seat fastener
manufactured from stainless - knurled thumb knob
no tools required, tighten and remove by hand
£3.50 inc UK P&P
ITEM 23
Front wheel bearing / 6202 bearing installer
bearing can be pressed on knocked in
£5.00 inc UK P&P
ITEM 24
Rear sprocket/brake stainless fittings kit and torque arm (both imges above)
£12.50 inc UK P&P
ITEM 25
mt500 brake pedal pivot bush and fittings
manufactured from stainless, includes pedal stop fitting.
service manual chapter 14 items 54,55,56,57,58,60,61
£6.75 inc UK P&P
ITEM 26
4 x exhaust downpipe clamp spacers
service manual chapter 5 item 10
£6.75 inc UK P&P
ITEM 27
2 x handlebar risers
stainless steel
please state length required
£13.50 inc UK P&P
ITEM 28
Set of 4 oil seal installers
includes crankshaft,camshaft,kickstart and mt500 front wheel hub seal.
can be supplied individually
£13.50 inc UK P&P
Image ---------------------------------------------------------------
ITEM 29
full stainless exhaust fitting kit.
including;
header studs, spacers and fittings
exhaust heatshield and silencer fittings
3 x stainless exhaust clamps
items can be purchased seperately
£20 inc UK P&P
ITEM 30
MT350 rear wheel L/H spindle spacer
this is modified on recommendations of current owners to enable split pin
to engage properly in castleated nut.
supplied with washer & st/st split pin
original item part number 84731098 service manual chapter 11 item 8 & 4
£5.75 inc UK P&P
ITEM 31
front wheel spacer - replaces the speedo drive
£8.50 inc UK P&P
ITEM 32
2 x stand stops/buffers
manufactured replacements
includes silicon paint protector - if required
service manual chapter 10 item 17
exhaust heat buffer
manufactured replacement, includes stainless fittings
service manual chapter 5 item 19
complete set £4.75 inc UK P&P
can be supplied separately if required
ITEM 33
Decompressor bracket/lever
supplied with fittings
unfortunately the cable adjuster is not stainless at the moment, as i'm having trouble sourcing one.
£11.50 inc UK P&P
ITEM 34
fork pre load spacers x 2
manufactured from acetal, ally, or stainless
price from £9.75 delivered (UK)
ITEM 35
mt350 exhaust silencer mounting spacer
parts manual plate 12. pt. no. 84711480 index 19
£4.25 inc UK P&P
ITEM 36
MT350 gun scabbard spacers, brace & fittings
comm. parts list section 2 items 28a,b & c. 29(84733013) 32,32a,b&c.
£21.50 inc UK P&P
ITEM 37
MT350 rear brake torque arm & fittings
comm. parts list section 6 item 47&48
£9.50 inc UK P&P
ITEM 38
cylinder head vice bracket.
secures the head simply in the vice
adequate room to remove valve etc
manufactured from stainless, with fittings
£7.50 inc UK P&P
ITEM 39
MT350 rear wheel, rear hub spacer, sprocket carrier inner.
comm. parts list. plate 6, index no.35, pt. no. 84732361
£6.95 inc UK P&P
ITEM 40
left side side stand bushes and fittings kit
service manual ch.10 items 20,21,22,23
£13.75 inc UK P&P
ITEM 41
shock mounting spacer
comm. parts list, section 3, item 12, part no. 84740687
£2.75 or £20 for all 8 inc UK P&P
BMW R1100S
Re: lathe work
Post by Minter » Thu Jan 19, 2012 7:44 pm
I can definatly recommend George's handy work! I've had 2 rear brake rods, one on blue and one for my 604 project. Plus other bits and pieces too. The knurled adjuster is a work of art and looks the biz!
Re: lathe work
Post by ZIP TIE » Thu Jan 19, 2012 7:46 pm
I have one of the rear brake rods and the split rear wheel spacer fitted to my bike they are top quality and the feel/power of the rear brake is much improved over the standard rod which has a spring like quality.
Mr Kay
Re: lathe work
Post by Mr Kay » Thu Jan 19, 2012 10:05 pm
Nice work George, the rose joint on the brake rod is a lovely touch.
Don't shout too loudly about the stainless though, you'll only get some moron telling you that it'll lead to a horrible death :roll: :lol:
P.I.STAKER
Re: lathe work
Post by P.I.STAKER » Thu Jan 19, 2012 10:12 pm
Mr Kay wrote:Nice work George, the rose joint on the brake rod is a lovely touch.
looks good though!!
BMW R1100S
Roy W
Re: lathe work
Post by Roy W » Thu Jan 19, 2012 11:24 pm
This is brilliant.
I needed a bush making and spent hours searching for an engineer locally to make it, to no avail.
The one man bands with a lathe are getting few and far bewteen.
PM sent
Roy
Re: lathe work
Post by ellrider » Fri Jan 20, 2012 7:08 am
You are doing the club a great service.
Just wish I was interested enough in the bike to take you up on it.
