Special tools?
Cato
Special tools?
Post by Cato » Sat May 16, 2020 11:27 am
It's been a while since I've owned an MT or anything with a Rotax single in it. I have the normal/general tools, so aside from the clutch holding tool and the flywheel puller is there anything else I should be adding to my kit?
1928 Motoconfort (in boxes).
1934 Magnat Debon.
1957 Enfield Bullet 350.
1981 GSX 1100 ET.
nige
Re: Special tools?
Post by nige » Sat May 16, 2020 11:31 am
Top cam sprocket puller. Easy to make from a bit of flat bar and tap threads in bar. Some sprockets slide off easy. But if loctited you will need a puller!
nige
Re: Special tools?
Post by nige » Sat May 16, 2020 11:43 am
Bottom pulley usually comes off easy, but after market pullers are available. Try to get a double ended one that fits crank pulley and flywheel.
nige
Re: Special tools?
Post by nige » Sat May 16, 2020 11:45 am
Clutch adjusting tool, cheap and makes the job quick and accurate, however, can be done without it with care.
Re: Special tools?
Post by Wirralman » Sat May 16, 2020 11:49 am
You have posted this query in the correct section. If you just click on the section the very first topic may help you decide
Re: Special tools?
Post by lardmarc » Sat May 16, 2020 11:50 am
AA or RAC membership.
nige
Re: Special tools?
Post by nige » Sat May 16, 2020 11:50 am
Finally! Make a crank locking bolt 8 mm Allen head with around 60 degree point ground on the end.
Cato
Re: Special tools?
Post by Cato » Sat May 16, 2020 12:06 pm
Wirralman wrote: ↑
I did see that, but it seems to be mostly discussing a basic tool kit. I was just after info on things like those in the replies here, pullers and so on, but if it's a duplicate post please delete it.
1934 Magnat Debon.
1981 GSX 1100 ET.
Re: Special tools?
Post by hounddog » Sat May 16, 2020 4:17 pm
Cylunder Head bolt spanner and flywheel puller also useful
Re: Special tools?
Post by arceye » Sat May 16, 2020 7:03 pm
One of georges valve spring compressors.
