MT350 or MT500 front frame loop
Any MT parts
Rotax640
Post by Rotax640 » Tue Feb 26, 2019 3:57 pm
Hi I'm looking for an MT350 or 500 front half frame loop, the front half of the frame comprising of the tank over the engine and head stock etc
Re: MT350 or MT500 front frame loop
Post by Minter » Tue Feb 26, 2019 10:37 pm
Post by Wirralman » Tue Feb 26, 2019 11:32 pm
Rotax640 wrote: ↑
I'm really struggling to understand what you're after. If you quote a part number, that would help
My nearest guess is that you already have a frame, the rear section is straight but the front is trashed so you plan to cut and weld it to a frame which has a straight front end to make a complete frame. That just doesn't sound right to me but is my interpretation of your post
Perhaps a brief description of what you are planning to do may help?
Post by Minter » Wed Feb 27, 2019 7:51 am
Ah I think you mean the front half of the frame with the oil in!
The 350 frame is one piece the 500 bolts together in the middle.
I may have one of those too..
Give us a call at Sportax Racing today and we will try and help you out..
Post by Derrick » Wed Feb 27, 2019 5:15 pm
I see from your earlier posts that you are re-building an MT500, so I assume it's the front half of the frame you are after. The MT500 frame is in two pieces that bolt together, but the MT350 frame is different and also one-piece construction.
1997 HD MT350
2002 Honda Pan European 1300
