Can am kicstart
Non MT related wants
Re: Can am kicstart
Post by mt bandit » Wed Oct 11, 2017 3:11 pm
doesn't any other bike's kick start fit, i can't believe that kick start was only made for that bike , some research is needed here , ( in case i bust mine )
Africa twin 750
honda hornet 600 now sold :(
mt 500
mt560e
can am
divorce coming soon
yeti341
Re: Can am kicstart
Post by yeti341 » Wed Oct 11, 2017 8:17 pm
Have you tried VCP online???
yeti341
Re: Can am kicstart
Post by yeti341 » Wed Oct 11, 2017 8:54 pm
You might have some luck with Al Roberts . or Tony Murphy rotax inc both in usa
Garychick61
Re: Can am kicstart
Post by Garychick61 » Thu Oct 12, 2017 6:12 am
Vcp are making another batch next month,the only other kickstarts that will fit seem to be off the can am 250 tnt basically the same engine no one that I've contacted seems to have any other suggestions.
Re: Can am kicstart
Post by mt bandit » Thu Oct 12, 2017 3:56 pm
what about having an engineering shop make a new splined knuckle
Africa twin 750
mt 500
mt560e
can am
divorce coming soon
Garychick61
Re: Can am kicstart
Post by Garychick61 » Thu Oct 12, 2017 9:08 pm
I'm going to look into that next week
Garychick61
Re: Can am kicstart
Post by Garychick61 » Thu Oct 19, 2017 10:49 pm
Mr Shiney wrote: ↑
Sun Oct 08, 2017 1:06 pm
Is it the kickstart itself or the splined part that you need? I have a kickstart lever but the spline part is knackered. So if your spline is fine you can swap them over.
Hi I have now found a knuckle,is the lever you have the circlip fitting thanks gary
Re: Can am kicstart
Post by Mr Shiney » Fri Oct 20, 2017 5:31 pm
I will have a look when I get back to the UK on the 31st. I can’t remeber off the top of my head.
Garychick61
Re: Can am kicstart
Post by Garychick61 » Sat Oct 21, 2017 10:29 am
Ok thanks
Re: Can am kicstart
Post by ZIP TIE » Sat Oct 21, 2017 5:20 pm
Isn't there two different types of kickstart lever (or knuckle) for the canam?
