Page 1 of 1
Loads of MT350 Parts and Some MT500 Bits
Posted: Fri Jan 26, 2018 1:24 pm
by TJRL
After eight years of MT ownership I find myself MT'less :cry: and with a fair sized pile of bit and bobs I no longer have a use for.
I am not sure how to ask but I have made a stab at a fair asking price by reference to the cost of the items new. Please PM if you are interested in anything and if needed I can provide photographs of them if you send me your email address.
P&P will be at cost or if preferred collection from Slough or Reading can be arranged, anyway here is the list:-
Brand New Unused Items
Description / cost New / Asking
Front mudguard £44.88 £27.50
Tool boxes complete with fixings and lid rubbers straps £51.54 £27.00
MT500 (also fits MT350) Speedo brand new and at zero miles £150.00 £100.00
Pannier mounting brackets (Mount, front upper LH, Mount, front upper RH and Mount centre) ? £25.00
Service manual in unopened packaging £41.99 £35.00
Clutch lever assembly £35.70 £17.00
Speedo cable £23.34 £15.00
Throttle cable £14.34 £8.00
Clutch cables £22.74 £15.00
Choke cable £12.60 £7.00
Decompressor cable £14.34 £8.00
Ignition barrel housing and ignition barrel £57.00 £30.00
ignition keys £5.40 £3.00
Indicator housing complete with lens £17.94 £10.00
Amber reflectors ? £1.00
Red reflector ? £1.00
Shrouds, clutch cable £4.50 £2.00
Cable boots, throttle £3.78 £1.50
Kick starter rubber £4.64 £2.50
Centre stand springs £16.20 £8.00
Headlight mount fork-tube £19.14 £10.00
H4 headlight adaptor rings £3.60 £2.00
Rebuild DVD £11.50 £7.50
Lowered seat £161.60 £125.00
MT250 black plastic tool rolls ? £2.00
Green air pump £11.94 £8.00
Black air pump £11.94 £7.50
Spark plugs £4.74 £2.00
Headlight bulb retainers £6.17 £4.00
Near New Items - Limited Usage
Locking fuel filler cap for plastic tanks (both 12l & 20l) £29.99 £22.50
Left hand switchgear genuine OEM fitted to bike for less than 80 miles (replaced with Apophis Part one) £46.74 £30.00
Left hand switchgear genuine OEM but missing “PASSING” switch flick-lever £46.70 £20.00
Chain tensioner kit for use if the centre stand is removed £11.98 £5.00
Used indicator stem £19.99 £10.00
Barkbuster S3 Storm plastic guards £30.57 £20.00
Pillion rear seat (bolts or clips onto rear rack) £56.90 £40.00
Tool kit complete with orange Rotax tool roll £71.40 £60.00
Air box complete with “trumpets” (not modified) £70.50 £55.00
Air box lid £13.44 £8.00
Pannier donut complete with all eight fixing bolts £53.82 £35.00
Pannier / Gunbox T-latch rubber £35.40 £17.00
Map case - Becoming very hard to find ? £15.00
MT500? oil filler cap complete with 5” dipstick (shorter than my MT350’s) £35.40 £10.00
Second hand Items
Pannier complete with lock, lock cover, instruction plate, latches and key £263.22 £125.00
Choke lever £21.00 £8.00
Indicator housings complete with lens & shortened/cut down mounting stalks £39.00 £20.00
Indicator flasher units £8.22 £3.50
Service manual – used and oily! £41.99 £15.00
Headlight cowl, a bit tatty £94.27 £20.00
Headlight cowl, with cut-out for clock, power socket and small LED lamp £94.27 £20.00
Headlight unit complete with HID converstion kit (plug and play) ? £60.00
Headlight unit £59.71 £30.00
Mirror head (no shaft!) ? £1.00
Front brake hose clamp (L/H fork leg) ? £1.00
Clutch lever blade £15.78 £8.00
Other
MT350 front rack to fit onto MT350 pannier donut £50.00 £35.00
Headlight guard – bolts onto outside of headlight cowl ? £10.00
Small windscreen - fits to handlebars ? £15.00
Front fork leg complete, but with semi striped thread on the axle clamping bolt £241.56 £75.00
Damaged pannier donuts £53.82 FOC
Home made aluminium adaptor plates, slip over MT350 pannier donuts in order to allow other things to attached to the bike ? £5.00
BMW foot rest rubbers, fit into standard MT footpegs ? £2.00
Stebel Magnum twin horn pack £35.00 £20.00
All must go or risk appearing on some selling website whose name cannot be mentioned!!
