Neutral light MT350
Dave892
Neutral light MT350
Post by Dave892 » Thu Jul 21, 2022 8:21 pm
My neutral light has suddenly stopped working. Ive removed the 5 light ‘panel’ hoping that the bulb may be at fault but its a sealed unit. When I put a volt meter over the two unplugged central contacts - its dead. Ive traced the wires back and can find no obvious faults. Is this a common problem and is there an equally simple answer without major work? I’m no mechanic and certainly no auto-electrician!
I can get a new light ‘panel’ for £70 (gulp!) but this seems a bit of a daft outlay if there’s no power going through with the ignition on in neutral.
Suggestions anyone??
Cheers.
Re: Neutral light MT350
Post by lardmarc » Thu Jul 21, 2022 9:08 pm
Check this.
Post by Wirralman » Thu Jul 21, 2022 10:21 pm
I'd remove and check the switch Lardmarc has indicated. If you need to renew it , go to LMS Lichfield - there may also be other compatible neutral switches
12royal
Post by 12royal » Fri Jul 22, 2022 7:11 am
Check this.
sprocket looks like its ready to be turned round 1/2 turn :D
Dave892
Post by Dave892 » Fri Jul 22, 2022 3:51 pm
Thanks everyone. Yes when i removed the sprocket cover - the cable was snapped and frayed. Ive ordered a new wire and switch for a few quid. Judging from the previous repairs to the wire - this looks like a common fault.
I’ll try the cable first but If the switch needs replacing - is this just a simple swap or will oil come pouring out? I have a manual but apart from acknowledging the existence of the switch, it barely gets a mention.
Thanks again
Dave
Post by lardmarc » Fri Jul 22, 2022 3:53 pm
Sprocket looks like its ready to be turned round 1/2 turn.
Of course.
Not my motor, it just happened to be on my kitchen floor without a sprocket cover.
Picture paints a thousand words.
Always first thing to check when neutral light fails.
It'll be the wire.
Tonydogbite
Post by Tonydogbite » Wed Aug 16, 2023 2:13 pm
Hi, where is that hole? My neutral light does not work,I’ve replaced the 5 light cluster and still no job. I’m no mechanic so I can see the picture but no idea where that is on the bike? Cheers.
Yours Aye
Tony
MT350E
Goldwing GL1500 Trike ;)
If gaffer-tape don’t fix it, you’re not using enough!
Vtrsp1da
Post by Vtrsp1da » Wed Aug 16, 2023 2:21 pm
Behind the sprocket cover
Dave892
Post by Dave892 » Wed Aug 16, 2023 3:31 pm
Yes just remove the sprocket cover from the nearside of the bike. You’ll see the wire running down in front of the sprocket (if fitted). It has a push fit connector. Follow it down to the switch which screws into the casing. Remove and replace as one unit with wire. I armoured mine up a bit with some heat shrink sleeve .
Post by lardmarc » Wed Aug 16, 2023 5:29 pm
If you can't figure out where that is on a motorbike you're probably better off taking it to a garage for them to repair.
You'll only hurt yourself.
4 x
