Likely 90/110 performance/mpg info
A place for you Landy'ers to converse without boring the rest of us (wink!)
ellrider
Re: Likely 90/110 performance/mpg info
Post by ellrider » Wed Oct 12, 2011 6:07 am
Mr Shiney wrote:The leg room is no different between a 90 and 110.
I am 6'1 and fit no problem.
Luckily it's a ragtop for the extra headroom.
ellrider
Post by ellrider » Wed Oct 12, 2011 6:13 am
Terry wrote: ....my 2CV does about 39/49 mpg,depending how I drive it ... :P
T.
How can you vary the driving of a 2CV. :lol:
mr v8
Post by mr v8 » Wed Nov 09, 2011 6:18 pm
my 1958 s2 88 inch with hand made rangy type chassis is just getting a 2.5 turbo engine and box setup, replacing the old v8. got a ground up new parts rebuild motor with turbo, should be sweet. am putting in a 300 tdi rad and intercooler. had the engine in something else to run it in for 5000 miles before fitting the turbo.
i also did the sherpa timing plate and belt conversion to lift the pump so you can fit the engine mt under the pump easily.
I think this can be a very nice alternative to the 200 tdi, if done correctly. one good idea is to use a 200 tdi crank, that stops a lot of trouble.
