Can-am/MT350 love child.
canam
Re: Can-am/MT350 love child.
Post by canam » Wed Aug 10, 2016 11:50 pm
Needed to make the back hole.
Purchased a corner round end mill.
Over-engineering replacement parts that were under-engineered originally by the manufacturer is the whole point of having a home shop.
canam
Post by canam » Wed Aug 10, 2016 11:56 pm
Test fit
It still needed a bit of finishing here.
More later
jungleMTbiker
Post by jungleMTbiker » Thu Aug 11, 2016 1:05 am
I'd be tempted to fill the corners with some sort of vibration absorbing potting. Of course that might make it hard to replace the battery...
--1985 Armstrong MT500, was 05 KE 27, currently hibernating in Surrey while I am back at work in Papua New Guinea.
--Fond hopes/dreams for my MT's future: electric start, Minterised 555 engine, disc front brake, better rear suspension
canam
Post by canam » Thu Aug 11, 2016 10:21 am
Last bits on this part.
Just got the sides to finish
I changed the design a bit and haven't gone for the mounting plate on the underside as it looked crap. So needed to counter sink some cap heads on the inside on the part and bolt it direct to the yoke. I used a little home make counter sink so they could be done. Didn't work at first then i remembered i had to run the drill in reverse.
Part of the way through polishing i put it on the bike and it didn't look very good. So i sanded it down with 2000 grit and gave it a clear coat of lacquer.
canam
Post by canam » Thu Aug 11, 2016 2:11 pm
jungleMTbiker wrote:I'd be tempted to fill the corners with some sort of vibration absorbing potting. Of course that might make it hard to replace the battery...
Its bolted in. Battery is just the back up so will last ages. I'm not 100% happy with it it looks loads better on the bike.
350biker
Post by 350biker » Fri Aug 12, 2016 9:14 am
Fabulous piece of aero quality work there Tony. Must get down to see you sometime soon as I have now bought a share in a PA28.
Ian Wilkinson
Retired Refinery Safety Engineer and now light aircraft pilot!
1949 BSA Bantam (rigid)
1971 BSA A65T Thunderbolt
1980 CanAm 250
1971 BSA B50 MXR2 (work in progress!)
jungleMTbiker
Post by jungleMTbiker » Sat Aug 13, 2016 1:50 am
Honestly I was thinking more about keeping mud and water out.
canam
Post by canam » Thu Aug 18, 2016 10:44 pm
Jet wash will fix that :D
Andi_Archer
Post by Andi_Archer » Fri Aug 19, 2016 6:45 am
Could you perhaps make a rubber insert from two pack compound similar to used on Mythbusters or maybe machine on from a rubber block as you have all the engineering kit?
Its all fun and games till someone loses their keys
canam
Post by canam » Fri Oct 21, 2016 4:17 pm
Back again.
Make a bit of a mistake on the headlight mount it looked great all wired up. Then i realised i couldn't remove it without loads of hassle.
So i cut a slot in it.
[url=https://flic.kr/p/MrLAWj]Image
