Can-am/MT350 love child.
canam
Post by canam » Fri Feb 22, 2013 1:23 am
Spare Can-am frame
Purchased an engine
Swingarm fits
Chop Chop
Fits in the hole
More photos tomorrow.
Over-engineering replacement parts that were under-engineered originally by the manufacturer is the whole point of having a home shop.
Re: Can-am/MT350 love child.
Post by ZIP TIE » Fri Feb 22, 2013 1:32 am
Wahey! Interesting project. :D
What running gear are going to use?
Greybeard
Post by Greybeard » Fri Feb 22, 2013 10:58 am
Nice project, i was thinking of doing this with my Can Am, although I was looking for a Honda engine as a donor.
I have done this before with other bikes.
Personally i would fit a single down tube to the frame from the headstock.
I also spot welded some bracing bars across the frame first as the frame tends to move once it has been cut.
It can be a lot more work than you think, electrics, drive chain pitch, engine and rear wheel alignment, Oil tank capacity, Engine weight differance etc.
Good luck, keep the pic's coming 8-)
Murdock
Post by Murdock » Fri Feb 22, 2013 12:28 pm
With some longer travel suspension you might be on to something :? Are you putting the diagonal frame members back in :?:
I have a couple of spare frames if any one else wants a go :?:
Can-am Bombardier 250 [McQueen]
Honda Valkyrie 1500 [Star ship cruiser]
VW T4 Surf bus [but dont surf]
If you have to ask "WHY" then you wont understand!!!
canam
Post by canam » Fri Feb 22, 2013 1:34 pm
ZIP TIE wrote:Wahey! Interesting project. :D
It will have standard back end with longer shocks
For the front it will be the same as my other Can-am. KDX220 forks brake front wheel. This will have Fazer 1000 yokes just putting a set on the other can-am. This setup works really really well offroad.
canam
Post by canam » Fri Feb 22, 2013 1:46 pm
Greybeard wrote:Nice project, i was thinking of doing this with my Can Am, although I was looking for a Honda engine as a donor.
The plan is to keep the twin down tubes maybe not the current ones on the bike. I prefer the look like on the rickman metisse I need to see how it will all work out when the other parts like the headers arrive.
The chain line looks very similar I worked it out to be about 3mm outwards. Oil tank from what I can work out is n the small side but should be ok ( fingers crossed on that one) I was going the feed the returns in the side of the filler tube with thin wall alloy pipe under the tank.
Thanks Tony
canam
Post by canam » Fri Feb 22, 2013 1:47 pm
Murdock wrote:With some longer travel suspension you might be on to something :? Are you putting the diagonal frame members back in :?:
Yep they will go back in and join up with the top engine mount area.
Greybeard
Post by Greybeard » Fri Feb 22, 2013 1:51 pm
I think the headers will be one of the bigest probs to over come, on many of the Rickmans the engines had splayed exhaust ports that cleared the frame tubes.
canam
Post by canam » Fri Feb 22, 2013 2:04 pm
Tank mount is getting in the way
Solved running 6.5 mm clearance lets me still remove the rocker cover.
Fits in the frame a bit better now.
Fits well on the underside allowing me to keep the standard pegs and mounts
New top mount needed and the diagonal tubes that i cut will need to join up with this.
Going to machine a spacer for this. That will angle the carb down a bit.
More later.
Yoof
Post by Yoof » Fri Feb 22, 2013 7:24 pm
canam wrote:Going to machine a spacer for this. That will angle the carb down a bit.
More later.
Something like this?
http://www.apophisparts.co.uk/mt500-inl ... apter.html" onclick="window.open(this.href);return false;
