Can-am/MT350 love child.
A place for current or ex-Can Am owners to natter..
canam
Contact:
Re: Can-am/MT350 love child.
Post by canam » Thu Mar 29, 2018 6:25 pm
Update i did some work on it last weekend and will get some bits done this weekend.
I also have a new larger milling machine so a few bits will be getting changed.
Over-engineering replacement parts that were under-engineered originally by the manufacturer is the whole point of having a home shop.
Barrie
Post by Barrie » Sun Apr 01, 2018 12:22 am
Bravo sir. Eagerly awaiting some pictures ;)
MT500 "Le Shuttle" In memory of Jim Burns
Jawa CZ 125
Need help uploading photos onto the forum?
click here
canam
Contact:
Post by canam » Wed Oct 10, 2018 8:10 pm
Quick update back working on it. Still wiring, changing a few bits around.
Post by mt bandit » Wed Oct 10, 2018 8:18 pm
Well done. I'm eagerly awaiting your next posts
Armstrong 600
500 outfit
canam
Contact:
Post by canam » Sat Oct 20, 2018 4:02 pm
Headlight mounts finished.
5 x
canam
Contact:
Post by canam » Mon Oct 22, 2018 12:04 am
I'm trying to keep things tidy with the wiring its a bit of a nightmare to keep it neat with things still happening with the build so it will all be tidied up at the end.
Running the wiring under the tank.
It looks like this inside the headlight.
I found a new Can-am ignition switch in my collection of bits so went with that. I couldn't think where else to put it.
I could find the red wire. In the end i found it folded back taped up in the loom for the switch. Very odd.
Cable ties are temporary it should all look neater in the end.
Looks a mess. I have a feeling this is "Mark 1" wiring loom.
Space is tight trying to get it all to fit in is a pain.
[url=https://flic.kr/p/Q9ycVW]Image
The Daytona digital speedo complicates things a little more. Extra wirings and finding somewhere to put the pickup for the speedo. I have been thinking about this quite a lot. Do i put it on the front wheel back wheel or front sprocket. I'm going for the rear wheel.
Putting it about here. I will make an adjustable mounting for it. Or do it go for the easy route on the front wheel i just don't like the idea of running the the cable down the brake hose.
microliteRon
Post by microliteRon » Mon Oct 22, 2018 1:43 pm
Looking a great job mate. Cant wait to see the finished product
tinytots
Post by tinytots » Mon Oct 22, 2018 5:50 pm
I glanced at this thread and started looking at the pictures and comments. I got totally engrossed in it and your progress, absolutely fantastic thread, can't wait for the rest of it.
yaka
Post by yaka » Tue Oct 23, 2018 12:11 pm
everytime i see an update i always end up reading it again from start to finish
canam
Contact:
Post by canam » Thu Jul 11, 2019 10:03 pm
Long overdue update on project.
All my other projects are done including 2 normal Can-ams and rebuilding my main Greenlaning Can-am. So i will try and make some progress on this one.
I have got loads more wiring finished or in the works. Still to wire neutral light, oil temp, rear light, brake light. All the trailing wires are there just need connecting up. Oil temp sender needs mounting some where.
I'm going to change a few things.
I'm going to change the headlight mounts on the forks. Looking back now they are a bit big. So i'm going to make the existing ones a bit smaller. More on this to follow. It will make sense when its done.
The carb mount i made doesn't look right and the carb sits at the wrong angle to the frame. So i'm going to make it out of one piece.
The magnet for the speedo pick up is done. I'm getting this anodised black. I still have to make the mount for the pick up the current plan is to weld a little block to the swing arm.
Users browsing this forum: No registered users and 5 guests
