ultimate mt
Re: ultimate mt
Post by Minter » Sun Nov 18, 2018 12:19 am
Hi Jamba, it's a rally raid product. The mount is home made and around a weeks work of on off on off add infinity!
MadStu
Re: ultimate mt
Post by MadStu » Sun Nov 18, 2018 10:34 am
I'll hopefully have the Ultimate MT soon.
Harley,
Front panniers for weather protection.
Front screen.
Bark busters.
Muffs.
Heated grips.
604 engine.
Normal sized tank.
Sheep skin.
Rear rack with box attached.
Rear rack, screen and panniers are easily removable if I want to take it offroad. And I can use it as a backup bike for work if ever needed.
HD MT604e - THE WUF
Armstrong MT405e - THE CNS
Re: ultimate mt
Post by appyarry » Sun Nov 18, 2018 11:19 pm
MadStu wrote: ↑
Harley,
Front screen.
Bark busters.
Muffs.
Heated grips.
604 engine.
Normal sized tank.
Sheep skin.
I thought you were getting a KTM? :-)
Re: ultimate mt
Post by deadgrass. » Thu Jan 17, 2019 7:12 pm
started trying out some more mods on my off road mt in the quest,
first job resite reg/rec
Re: ultimate mt
Post by Wirralman » Thu Jan 17, 2019 7:28 pm
deadgrass. wrote: ↑
Are you planning a shield of some description to keep our mud and water yet still allow heat to dissipate?
Re: ultimate mt
Post by deadgrass. » Thu Jan 17, 2019 7:45 pm
was just gonna try running it like this eric,
if it clogs up with mud i may rethink this,
Re: ultimate mt
Post by Wirralman » Thu Jan 17, 2019 9:37 pm
I was thinking of water ingress. Given that these are quite expensive to replace, and the bike is intended for off road use, it looks at little exposed. I'd be tempted to create some sort additional barrier. Tricky as you don't want to create something that traps water either..
Re: ultimate mt
Post by deadgrass. » Fri Jan 18, 2019 1:01 pm
not too worried about water,its sealed up well and quiet exposed in its original position,
mud clogging the fins is a worry,
not sure how hot these get when working [must remember to touch it]
don't even know when they are working hard [heating up]
is it when the engine is revving hard [gen output] or when say lights heated grips on [load]?
i'm rubbish with electrics.
Re: ultimate mt
Post by deadgrass. » Sat Jan 19, 2019 5:04 pm
another mod, trial screen and lighting upgrade,
a bit scary looking
Re: ultimate mt
Post by appyarry » Sat Jan 19, 2019 6:21 pm
It looks great, will it pass an MOT with those lights??
