Clutch Basket sorted
gegdonnell
Post by gegdonnell » Thu Aug 18, 2016 7:46 pm
Have sorted my clutch basket, was having difficulty selecting gears, now all back together thanks to Minter's advice and spares.
Re: Clutch Basket sorted
Post by Minter » Thu Aug 18, 2016 8:12 pm
gegdonnell wrote:Have sorted my clutch basket, was having difficulty selecting gears, now all back together thanks to Minter's advice and spares.
Good news Geg - hope to see you at the N wales bash..
gegdonnell
Post by gegdonnell » Sat Aug 20, 2016 2:25 pm
Maybe will see how things go.
muzuki
Post by muzuki » Thu Aug 25, 2016 11:03 pm
I have been having similar problems. What was it you had to do to sort it?
Post by Minter » Fri Aug 26, 2016 7:40 am
You have to remove the clutch basket and file the grooves out caused by the friction plates digging into it. This can only be done a couple of times before the gap becomes too great causing similar gear selection/ dragging problems etc. Its a good chance to inspect all the components and replace old gaskets seals and O rings.
We do a kit specifically for this and can be seen here which is currently on sale.. http://sportaxracing.co.uk/shop/kits/cl ... t-999-015/
Hope that helps
