Red's mt
Red
Red's mt
Post by Red » Thu Apr 21, 2016 7:43 am
A few pics of one I'm slowly putting together
Tank cutouts for steering lock
Cut and welded brake lever, master cylinder mounts welded onto frame
Welded the bash to the crossmember, more stiffness and importantly stop them darn bolts vibing out with the 81mm crank, lowered the bash 3mm as sits a bit tight to the sump stock (ta gonzo for the idea)
Opened up the box to take a vm44 and micra k&n to suit
Exhaust in progress
Slightly raised rack
Re: Red's mt
Post by appyarry » Thu Apr 21, 2016 7:51 am
Looks Good, a lot of work, but good :-)
MT 604e :-)
Red
Re: Red's mt
Post by Red » Thu Apr 21, 2016 8:08 am
Cheers yeah this one is like a second job!
Re: Red's mt
Post by bth2bth2 » Thu Apr 21, 2016 2:07 pm
phew....i thought it was going to be a red one :lol:
Red
Re: Red's mt
Post by Red » Thu Apr 21, 2016 2:54 pm
Nah the red refers to the ginger trucker that's guna pilot the thing... Sure there's more of them red ones now than were ever made anyhow
Blitz
Re: Red's mt
Post by Blitz » Thu Apr 21, 2016 8:38 pm
That exhaust looks Mahoosive :twisted:
Red
Re: Red's mt
Post by Red » Thu Apr 21, 2016 8:50 pm
Tis a bit, the ideal pipe I worked out wanted that back pipe to be almost a inch bigger and the can another 1.5" bigger :roll:
Gots me one of them ignetech programable ignitions as well to make things harder for myself....I mean run better
Red
Re: Red's mt
Post by Red » Sun Apr 24, 2016 4:50 pm
Had a go at the end can, first time I've welded stainless so welds not beautiful but could be worse lol
Welded in a 2.25" inlet stub, 2.5" baffle and packed it
Welded a flat back onto it to tuck it in as close to wheel as I can not to have too much silencer hanging out the side
Imagev
Corner off a stainless turbo flange made a neat little mount, moved it up so can mount it on the same mount as the rack so can trim off the extra mount I had put on the frame
Re: Red's mt
Post by appyarry » Sun Apr 24, 2016 7:43 pm
Red wrote:Gots me one of them ignetech programable ignitions as well to make things harder for myself....I mean run better
I'm really interested in seeing how this goes.
I have a variable ignition module on my Lambretta and it works really well. I'm conversing with the maker who is very helpful and the next step is to buy one that allows me to program my own curves rather than having 20 or so set mappings.
MT 604e :-)
Red
Re: Red's mt
Post by Red » Mon Apr 25, 2016 9:03 am
My mates had a play around on his two stroke with different preset cdi's and had good results as well, I've got the standard rotax map as a starting point, hopefully will be able to improve Tickover and getting it running reasonably well
Throughout the Rev range with a lumpy cam and large carb
The standard cdi seems to be the same from the 350 motor to the 636 which doesn't seem ideal! This ones made to replace that so plug and play into the loom just needs one 12v live running to it
