The Son OF The Return Of It's To Late To Stop Now
gronk
Post by gronk » Sun Mar 29, 2015 1:12 pm
As you may or may not be aware the engine in my 500 has been a bit poorly of late
SO THERE IT WAS
AND HERE IT IS NOW
SO WOTS GONE ON ERE THEN..................Answers on a postcard please
KEEP IT GREEN
namtip
Re: The Son OF The Return Of It's To Late To Stop Now
Post by namtip » Sun Mar 29, 2015 1:36 pm
:o
Running lean getting too hot?
Post by arceye » Sun Mar 29, 2015 1:40 pm
They are not meant to run on diesel. :lol:
MT 405
Post by mt bandit » Sun Mar 29, 2015 1:53 pm
wouldn't the plug be white ish if it were too hot ?
is the debris on the piston, carbon deposits?
Africa twin 750
honda hornet 600 now sold :(
mt 500
mt560e
can am
divorce coming soon
Post by appyarry » Sun Mar 29, 2015 1:57 pm
Looks like the liner has broken up or maybe you have ingested something down the intake?
A Sportax CC upgrade should sort it though. Interested to know what happened.
Ta,
gronk
Post by gronk » Sun Mar 29, 2015 3:57 pm
mt bandit wrote:wouldn't the plug be whiteish if it were too hot ?
The debris on the piston, is not carbon but mashed up bits of piston. It seems to me that the liner has cracked around the top, and the top piston ring has gone into this crack on the down stroke ripping the top edge off the piston and pulling the liner down slightly. Has anyone known anything like this happen before, or are my assumptions wrong.
A PICTURE OF THE PLUG
KEEP IT GREEN
skippy1970
Post by skippy1970 » Sun Mar 29, 2015 4:25 pm
From what I can see in the pictures Gronk your assumption is right
I've seen a few piston crowns come away before but not the liner
Hopefully the liner failure is just a one off
On the positive side it looks like no rubbish ended up in your bottom end :shock:
gronk
Post by gronk » Sun Mar 29, 2015 4:52 pm
skippy1970 wrote:From what I can see in the pictures Gronk your assumption is right
Yeah None of the rubbish has gone past the piston rings, and the engine sounded sweet until this happened so I plan to leave the bottom end well alone.
KEEP IT GREEN
Post by bth2bth2 » Sun Mar 29, 2015 5:31 pm
wasn't through a lack of oil was it? silly things do happen. at least it hasn't got into the bottom end. only partialy expensive :?
gronk
Post by gronk » Sun Mar 29, 2015 5:50 pm
bth2bth2 wrote:wasn't through a lack of oil was it? silly things do happen. at least it hasn't got into the bottom end. only partialy expensive :?
Oil level was OK and and you could see the oil pumping round by looking down the filler cap. I checked this only the day before the Cat and Fiddle meet (day of the brake down).
KEEP IT GREEN
