ultimate mt
Re: ultimate mt
Post by deadgrass. » Sat Jan 19, 2019 6:36 pm
appyarry wrote:
Sat Jan 19, 2019 6:21 pm
It looks great, will it pass an MOT with those lights??
i doubt it phil,
these are the first ones i bought [there's lots to choose from] these are 18w flood beam pattern,
i have just ordered some 20w spot beam pattern to try [only £13 a pair]
Re: ultimate mt
Post by twmtomos1 » Sun Jan 20, 2019 8:00 am
Dave ,i think the regulator gets hot up until the battery has had its full power back,
Re: ultimate mt
Post by deadgrass. » Sun Jan 20, 2019 10:38 am
thanks keith,
just for reference,
i also did a quick test on power usage on the led lights
battery at 12.73v to start,
lights on with engine not running for 10 mins
new battery test at 12.70v
so not much drain on the battery.
Re: ultimate mt
Post by deadgrass. » Fri Jan 25, 2019 7:48 pm
another thing i've been trying to improve is the standard front drum brake,
untested as yet,
Bonnielad
Re: ultimate mt
Post by Bonnielad » Fri Jan 25, 2019 9:08 pm
Saftek in cleckheaton will reline your shoes and skim the drum so you get a perfect match for maximum contact. Made a big difference to mine and not too expensive. Can’t remember exactly but I think it was about £50 for the full job
1985 Armstrong MT500 "Black Bomber"'
2019 Honda CB500X
Re: ultimate mt
Post by deadgrass. » Fri Jan 25, 2019 9:27 pm
thanks steve good to know,
i'm only dipping my hobnailed boot in the water at the moment so to speak,
be a good mod if it works though 8-)
Re: ultimate mt
Post by twmtomos1 » Sat Jan 26, 2019 8:24 am
Hi Dave your to young to remember hobnailed boots ,unless they have just come to fashion in your area :D
Re: ultimate mt
Post by Minter » Sat Jan 26, 2019 8:44 am
I experimented with a twin leader drum set up. When it worked it was good but had to adjust it all the time.
In the end I went back to standard after getting drum reground and shoes to match as Steve mentioned..
Re: ultimate mt
Post by Minter » Sat Jan 26, 2019 8:54 am
Progress on my ultimate MT is coming on!!
Re: ultimate mt
Post by deadgrass. » Sun Apr 21, 2019 4:47 pm
work has got in the way of bike tinkering of late but i've been playing around with a ccm swing arm [as others have done before me]
