Mt 350 Harley
Woody
Mt 350 Harley
Post by Woody » Sat Nov 03, 2018 3:32 pm
Could anyone tell me the correct tension for the timing belt, as we've got a bit of play and would like to adjust it
Wiody
Re: Mt 350 Harley
Post by lardmarc » Sat Nov 03, 2018 3:41 pm
It never hurts to watch this.
https://www.youtube.com/watch?v=-GonzLESgPI
Not me obviously, I adjust with a BFH.
Re: Mt 350 Harley
Post by Wirralman » Sat Nov 03, 2018 4:47 pm
There should be some play on the belt
If you tension it too much you will wear bearings unnecessarily, too loose and it may slip a cog
The correct way to do the job can be found in the manuals. I can't remember ever removing the tensioner itself . Equip yourself with cleaning rags, if the belt has been on for a while the belt will have shed some rubber
You should find an O ring around the edge of the cover housing, that will need to be seated. It should go around the edge but never be waterproof, there's a drain hole for that which is worth clearing ( If you can't find one - look harder )
There are torque setting and any loctite requirements in the manuals
Re: Mt 350 Harley
Post by hounddog » Sat Nov 03, 2018 4:53 pm
http://www.qtg.co.uk/motorbike/files/mt350/20files.htm
Cambelt Tutorial should answer this
If you dont know how old the belt is take the opportunity to renew it , with the correct Dayco one
Re: Mt 350 Harley
Post by lardmarc » Sat Nov 03, 2018 5:07 pm
Too loose and it may slip a cog.
It doesn't need to be loose to slip a couple of teeth.
Re: Mt 350 Harley
Post by Wirralman » Sat Nov 03, 2018 5:18 pm
As for the belt itself Dayco is the de facto standard but I think there is an alternative. The key thing is not to buy a machine belt, it must be designed for bike use.
If you look on the forum you may find references to these with comments like 'They're (machine belts) fine , don't know what the fuss is about' but the riders don't ride their bikes very much ......
Check you pulleys for wear whilst you are doing the job
Re: Mt 350 Harley
Post by lardmarc » Sat Nov 03, 2018 5:27 pm
Gates also make a belt for them.
None of the proper outlets are going to sell you a machine belt.
Johnevans
Re: Mt 350 Harley
Post by Johnevans » Mon Jan 28, 2019 7:11 pm
6mm with a 5lb force
