Rack bits missing?
StewartR
Rack bits missing?
Post by StewartR » Sat May 19, 2018 9:16 pm
Hi!
I collected my MT today. Seized brakes at the back and no sign of having run for a while but not bad aside from that...I hope ;)
I came with panniers frames but only the baskety bits. Is that all there is? They seem to have bolts holes with no corresponding mounting point on the bike so am I missing bits?
Cheers,
Stewart
‘89 MT500
‘02 Honda VTR1000
‘91 Honda Africa Twin (RD04)
‘78 Moto Guzzi 1000sp
Re: Rack bits missing?
Post by Wirralman » Sat May 19, 2018 10:05 pm
You can take the calipers apart easily enough The hard part is removing the bolts joining the two halves Left on the bike you should be able to unscrew them , then strip and clean A refurb kit is worthwhile Just make sure you re- assemble correctly The rear master cylinder catches crud and may also need attention
Go to the Technical section of the forum and download the manuals so that you find out exactly what should be there From what you have described I think you may be missing donuts
Should you find yourself needing parts, it's always worth posting in the Wanted section
Post by ZIP TIE » Sun May 20, 2018 4:15 am
500 or 350?
StewartR
Post by StewartR » Sun May 20, 2018 5:40 am
Oops - forgot to mention. It's a 500.
‘89 MT500
‘02 Honda VTR1000
Post by Wirralman » Sun May 20, 2018 6:32 am
Sorry my comments above largely relate to the 350 but 500 manuals are available for download
Post by Minter » Sun May 20, 2018 12:32 pm
Welcome to the forum Stewart..
Sportax Racing
Post by ZIP TIE » Sun May 20, 2018 2:33 pm
On the 500 you need the rear rack (behind the seat) as well as the side panniers as this mounts to the bikes frame and the side panniers mount to the rear rack
StewartR
Post by StewartR » Sun May 20, 2018 6:12 pm
Cheers. Had a better look and it turns out I do have all the bits apart from the longer bolts. Happy days as I have plans to haul tour on the old girl.
‘89 MT500
‘02 Honda VTR1000
Post by ZIP TIE » Sun May 20, 2018 6:50 pm
I have seen Allthread (threaded bar) and 2 nuts used to replace the longer bolts if thats an easier fix for you
