Page 1 of 1
A little help from a friend or the general public !
Posted: Fri Apr 27, 2018 8:56 pm
by Born agN Biker
Hello again everybody,I have had a tough start to the year what with one thing or another ,truth is my life has been turned upside down but I don't want to bleat on about that on this post .
The thing was I had seen the post about stolen bikes and I thought yer there are some nasty people about ,but I had to tell you all what happened to me yesterday just to balance things up a bit ,I had been out and about on the old bike and had a reasonable ride round Oxfordshire and West Berkshire however around four o'clock I intended to stop in a car park for a break. As I pulled in I noticed a couple of cyclists who were looking at the bike ,when I stopped they came over to me they had noticed smoke and oil coming from below the tank .
We all had a good look and it was not good..... if you see what I mean !
The bolts on the rear rocker cover had come loose and one had gone completely ,there was oil everywhere ,straight away they were on the phone ringing somebody local to help me out ,a phone call by a complete stranger had saved the day for me because I was well and truly stranded, In less than half an hour I had managed to limp into Didcot and stopped again at a tyre centre where two chaps came out and had a go at fixing the problem at the side of the road and gave the bike a bit of a clean up as they gave me directions to my destination. A lady pulled up and offered to give me a lift to the garage ...so that was five complete strangers giving there time to help me .
I was now on my way again after the bike had cooled down a bit and a short ride to TB Motorcycles where Tony was waiting to see what the problem was ,he took the bike from me and within half an hour had it sorted out topped up, cleaned up and ready to go he was fantastic ,they all were !
I have seen the you tube videos of people getting angry with bikers but I can tell you there are some REAL GOOD people out there as well !!!!
Re: A little help from a friend or the general public !
Posted: Fri Apr 27, 2018 9:17 pm
by hounddog
That's nice to hear , there are a lot of good people out there
Posted: Fri Apr 27, 2018 9:34 pm
by Wirralman
It may be worthwhile going right through the whole bike doing a check/tighten procedure on nuts and bolts I'd be concerned about what else there is- use the service manuals for guidance
Posted: Fri Jun 08, 2018 9:43 pm
by Born agN Biker
Yes since that day I have been doing a general check over here there and everywhere and I have found one or two things that will need to be fixed over the winter time .
I would be interested to hear what other riders have found with regard to how effective the rear brake is on their own bikes ,on a scale of 1 to 100 I would say mine score about 55 ! maybe that would be another job for the winter list .
Enjoy the weekend !
Happy and safe riding to all !
Thanks.
Posted: Sat Jun 09, 2018 7:25 am
by Wirralman
Re rear brakes, are you talking 350 or 500?
Some who ride off road prefer a softer 500 drum brake rather than a 350 disc because it gives more feel
Both bikes need attention to rear brakes, on 500s riders have reported 'oval' drums and have renewed them Some have reported desalination where the friction material has come away from the shoe
On 350s the problems are, clogged calipers which don't allow free pad movement, clogged master cylinder -
mud restricting piston movement, poor pedal adjustment , some have noticed an improvement when they have renewed brake lines So for a complete job :-
1 strip caliper, clean and fit new seals
2 renew pads ( there are different grades available)
3 renew and upgrade brake line
4 strip, clean and renew rear master cylinder
5 replace all old fluid ( if you only partially strip)
6 set up master cylinder free play correctly
Your rear brake will be 100% in no time
Posted: Wed Jul 04, 2018 8:38 pm
by Born agN Biker
Yes I have the 350 with the discs so a number of things that could be done to improve them .
I had better start saving up for the bits !
Thanks to Wirralman
Posted: Wed Jul 04, 2018 9:56 pm
by Wirralman
Low cost option is simply cleaning
Take wheel off and pads out then clean old brake dust away ( mask up to avoid inhaling dust) Clean inside of caliper to ensure pads move freely Ditto retaining pin and tensioner
Clean pads so that they can slide in and out freely
Scuff up existing pads if they are glazed
Item 4 refers to rear master and jobs are
Clean crud to ensure piston makes freely
Renew brake fluid and bleed
Set up master piston to ensure correct free play
Cost
Elbow grease
Clean rags
File to de-glaze
Brake fluid
Bleed screw spanner
Had I not said Fit new pipe, someone else would pointing out that old rubber pipe may swell under pressure
So , you can tackle this without breaking the band and you may well solve your problem for buttons
If not it's save up for refurb kits , pads and pipe😊
Posted: Wed Jul 04, 2018 10:18 pm
by Dave_S_MT
As above re the back brake on my 350 - was pretty pants when I first got the bike, gave it a thorough clean and covered a few miles - all good. Didn't take long at all.
