MT Teeshirts
MT Teeshirts
Post by Wirralman » Fri Apr 14, 2017 3:30 pm
A few years ago I compiled a list of FAQs with the collective knowledge of owners
It started with the section below Some newer members may find it of interest
As an aid to understanding MT’s and what goes wrong with them, here are some of the MT ‘Tee Shirts’ you can acquire throughout your ownership of an MT.
1 My carb overflow is pouring out fuel
2 My airbox has a puddle of fuel in it
3 My petrol tank and carb bowl were full of rust and sand.
4 My oil gushed out of front tube all over garage floor
5 I put too much oil in, now my airfilter is soaked and oil is covering the engine
6 I washed bike, now it won't go
7 My run switch shorted out in the rain
8 I can’t find neutral
9 I pulled the clutch in, selected 1st and the bike jumped forward 2ft then stalled
10 My starter motor makes a clunking sound
11 My lights and horn have suddenly stopped working
12 I ran out of fuel today
14 My tank has no reserve
15 Changed my cambelt today, but now my starter won’t crank
16 I opened a thread with a question that was answered in FAQs
17 My cambelt snapped but my spare was at home
18 I didn’t realise I’d knocked run switch
19 I didn’t realise I’d knocked blackout switch
20 I had brake fade today
21 I can’t get my brakes to bleed
22 I did carb mod and now have a flat spot
23 I did the carb mod and it now goes like stink
24 I broke my clutch cable and rode home with no clutch.
25 I broke my key in the steering lock
26 My Armstrong always starts second kick, unless there’s a crowd watching
27 I lost a centrestand spring today
28 I thought the red light was an oil pressure warning light or a charging light
29 I bunkered my bike home today
30 I bought an Original spare, then found a member selling one for a fraction of the price
31 I’m building up a supply of spares
32 I agonised over which colour paint to use,
33 I’ve routed a spare clutch cable in place
34 I hardly ever change my oil and run my bike infrequently because the clutch is sticky
35 My bike wouldn’t run at high speed, I loosened the filler cap and it flew.
36 My bike doesn’t run too well when the engine gets warm.
37 I asked what TP and ACCS stood for
38 What are those pointy things on the front of my MT350 handlebars?
39 Where does my MT500 pump fit ?
40 So the odometer is in km and the speedo is in MPH ???????????????
41 My metal plug cap arcs in rain
42 Went to a bike meet and parked the amongs t lots of exotic machines, but the MT attracted most interest.
43 I found some dodgy wiring on my bike
44 Bought an MT, then another....
45 I’m going to strip it down and rebuild it...
46 You don't need a f*****g chain tensioner !
47 You DO need a f*****g chain tensioner
48 I had to explain that my MT was not in WW2
rustybike
Re: MT Tee shirts
Post by rustybike » Fri Apr 14, 2017 3:50 pm
Eric.
Here is another...
Why did I buy an MT?
What colour green paint should I use
Lets get out there and Tw^t it!!
Barrie
Re: MT Tee shirts
Post by Barrie » Fri Apr 14, 2017 5:11 pm
Brilliant. I forgot all about this. I have looaads of those tshirts!
Now to just get the old FAQS up ;)
Barrie
MT500 "Le Shuttle" In memory of Jim Burns
Jawa CZ 125
Need help uploading photos onto the forum?
click here
Re: MT Tee shirts
Post by Wirralman » Fri Apr 14, 2017 6:42 pm
rustybike wrote:Eric.
Here is another...
Yes paint does come up frequently A later section of FAQs gave MT500 priming and UK colour code ( I don't know if RAL existed when they were made) Also the American paint code suspected used originally together with closest RAL code
sparkieb2
Re: MT Teeshirts
Post by sparkieb2 » Mon Nov 06, 2017 9:37 am
I can add " started it in gear and we both fell over" wouldn't have been so bad if i hadn't been in front of about 100 others :oops:
Yorkshire & retired 👍
FordPrefect
Re: MT Teeshirts
Post by FordPrefect » Tue Nov 07, 2017 6:12 am
There's also "I pinched my inner tube with the security bolt"
1993 MT350 bought August 2017
rustybike
Re: MT Teeshirts
Post by rustybike » Fri Nov 10, 2017 5:58 pm
There should be a T shirt that says "F##k me it passed it's MOT... :o "
