hawk61
Post by hawk61 » Sun Sep 16, 2018 5:43 pm
Refitted rear shocks correct way as they was fitted up side down valve at bottom and found 2 bolts were loose on rear brake stay bar still few other bits to do another day
hawk61
Post by hawk61 » Sat Sep 29, 2018 2:19 pm
Change carb to dellorto 34 just need to change cable as it's not long enough previous owner over filled oil it was all over engine frame when I took filler cap of to check
highland al
Post by highland al » Sat Sep 29, 2018 3:02 pm
Just spent a few hours swooping over fastening for nice shiney stainless steel.
Hal
tinytots
Post by tinytots » Sun Sep 30, 2018 8:49 am
Just finished painting camo from white. The baffle as come loose in tail pipe, so going to weld that up today.
pop
Post by pop » Sun Sep 30, 2018 6:07 pm
just got back from 4 hour ride on Salisbury plain with petrol leaking from carb overflow pipe, wacked float bowl with screwdriver handel but still leaks...now taking off float bowl to investigate
Post by mt bandit » Thu Oct 04, 2018 7:56 pm
Fitted the new 36mm delorto to my outfit today .removed the mikuni carb as I really don't like them Coz of over fuelling .
It was a difficult job as the delorto is rather large .
Best way I found was connect the two rubbers to the carb . Undo the air box to give yourself a bit of tolerance and jiggle 😎
Firing her up tomorrow
Africa twin 750
honda hornet 600 now sold :(
mt 500
mt560e
can am
divorce coming soon
tinytots
Post by tinytots » Fri Oct 05, 2018 3:01 pm
New front tyre fitted and baffle welded.
hawk61
Post by hawk61 » Sat Oct 06, 2018 5:42 pm
Took about two litres of oil from bike as it was over filled from previous owner shorten outer throttle cable running better refitted choke from left side of right side as when turned to left it was pulling choke on just need to test ride now maybe Sunday
Monkey104
Post by Monkey104 » Tue Oct 09, 2018 7:25 pm
Been meaning to change tyres for two weeks. Last week in the rain I braked, the bike didn’t!
We both went down. Result is: bruised arse, bent handle bars, knackered switch gear, one bent bark buster and a little light scratching.
So I have replaced the tyres, switch gear, bar and bark buster. Took a codeine for the bruised arse but found nothing to take away the self recrimination!
phil
Post by phil » Wed Oct 10, 2018 8:45 pm
Came to replace rear brake shoes, noticed wheel bearings seal has come off, ordered new bearings, whilst fitting them noticed a couple of spokes had broken again! Decided to replace them all so have just ordered new ones from central wheels. While I am waiting for them Ill get the hub and rim powdercoated.
So much for a quick job!
