MT350 new rider ,need a machanic
Forum rules
Persevere - we're worth it!
Re: MT350 new rider ,need a machanic
Post by Derrick » Wed Jan 02, 2019 4:49 pm
Welcome rujjeb. At least you have it running, so it's going the right way.
Check the cam-belt, it can run but be rough when it's a tooth out. If you don't have the workshop manuals then have a look around the forum, there are links to them somewhere.
It's worth making sure you are using fresh fuel. Modern fuels deteriorate after a few months. As said earlier, check the carb rubbers,the carb to engine rubber can get split which will give a weak mixture.
1997 HD MT350
2002 Honda Pan European 1300
P.I.STAKER
Post by P.I.STAKER » Wed Jan 02, 2019 6:34 pm
Hi and welcome to the forum
good luck with the bike
https://sites.google.com/site/gvsparts/
ARMSTRONG MT500 1984
BMW R1100S
