My 350 oil problem
Forum rules
Persevere - we're worth it!
Stephen Colloby
My 350 oil problem
Post by Stephen Colloby » Fri May 25, 2018 9:52 pm
Hi recently bought a mt350 fixed the starter sprang now having problems with the oil coming back to the tank and not reving up fully any ideas cheers Steve
Re: My 350 oil problem
Post by deadgrass. » Fri May 25, 2018 10:17 pm
Timing not set correct after sprag fix? (Not reving out )
Dave.
Post by Wirralman » Fri May 25, 2018 10:49 pm
If you have an air lock or the oil pump is faulty then oil may not be lubricating you engine properly hence its reluctance to rev
Dave has already mentioned a common problem which may also be a factor
Torn or perished rubber airbox-carb or carb- engine
Dirty carb, clogged jets, torn/weak diaphram ( main snd acceerator pump) Float setting/ punctured float
Clogged tank, fuel tap, anti-tilt valve
Silencer rusted out internally
Poor electrical connections? NB Earthing point behind the horn
Spark plug, HT lead
Valve timing /worn valves
Some things to look at
Post by Minter » Thu May 31, 2018 9:16 am
Welcome to the forum Stephen,
Did you lay the bike on its right hand side when doing your sprag job?
Is your air box now full of oil?
Also check the points made by Dave and Eric above!
Good luck
Sportax Racing
