New member
Forum rules
Persevere - we're worth it!
Re: New member
Post by Derrick » Wed Oct 04, 2017 7:40 pm
Welcome fafs, as hounddog said, they are not smooth and silky engines. Some are noisier than others, but as long as it's running OK and has oil then it should be fine.
1997 HD MT350
2002 Honda Pan European 1300
fafs
Re: New member
Post by fafs » Fri Oct 06, 2017 10:59 pm
Thanks i am now quite happy with the engine noise, it seems normal !!! It starts great when warm but needs about 10 kicks when cold
gegdonnell
Re: New member
Post by gegdonnell » Sun Oct 08, 2017 5:36 pm
Hi and welcome, you have to develop the knack to kick start an Armstrong, my MT 350 comes with electric as well as a kick start.
Re: New member
Post by Wirralman » Sun Oct 08, 2017 6:10 pm
gegdonnell wrote: ↑
It's worth MT350 owners practicing their kickstarting technique though, for the day your battery suddenly expires
Re: New member
Post by twmtomos1 » Sun Oct 08, 2017 6:50 pm
for newbies its worth knowing the little window in the cambelt cover /the white dot, is when you kick start ,thats why its there,makes starting easy ,good luck
Re: New member
Post by Minter » Mon Oct 09, 2017 9:56 am
Welcome to the forum fafs
Sportax Racing
fafs
Re: New member
Post by fafs » Sat Nov 04, 2017 6:56 pm
Minter wrote: ↑
Sportax Racing
Cheers Minter
Daysmith
New Member
Post by Daysmith » Sat Dec 29, 2018 9:38 pm
Hi, I recently bought a Mt500 from nice chap in Scotland... got a good price because it's got a white smoke problem. Otherwise excellent condition.
I'm in the process of mildly customising... junked the headlight and brick like binnacle made a replacement, wanting to put a larger front hub on..nearly ran into a fence coming down my lane ! I'll post some photos tomorrow.
But back to that smoke..... thinking either stem oil seals or piston rings ? Will be doing a compression test ... does another know what figure would be healthy ? Circa 160 ? Also can head be removed without taking engine out...looks tight !
Any advice would be welcome...thanks for letting join
Regards Paul
Re: New member
Post by Minter » Sat Dec 29, 2018 11:47 pm
Hi Paul,
Your best putting your questions in relevant section as welcome posts get culled after time.. technical sections are saved and can be found easily..
Stem seals would smoke blue on start up then clear. Blue smoke on over run is oil control ring, blue smoke all the time is worn out rings, pidton and cylinder or head gasket leaking oil into combustion chamber.
Motor has to come out to remove head.
You'll be lucky to get anywhere near 160psi by kicking but 120 would be ok.
Hope that helps
Sportax Racing
Daysmith
Re: New member
Post by Daysmith » Mon Dec 31, 2018 12:28 am
Hi Gary, Thanks for your reply. No smoke on start up....appears to be white smoke once rev d hardish... thinking it might be the mixture, previous owner did fit a new carb....but I'll start with comp test.
Thanks again
Actually it is leaking some oil on cylinder head gasket area ..... taking the engine out has dampened the spirits a bit !
