my mt500
Forum rules
Persevere - we're worth it!
dick sauve
my mt500
Post by dick sauve » Thu Oct 03, 2019 11:53 am
I have just got a mt500 serial # mtc0001, is this a Canadian regerestered motorcycle.
Re: my mt500
Post by Wirralman » Thu Oct 03, 2019 12:52 pm
Welcome to the forum
You have a very special bike No 1 of the Canadian build of about 75
Many will be envious, a 500 with electric start, the UK military spec only had kick start
dick sauve
Re: my mt500
Post by dick sauve » Thu Oct 03, 2019 4:58 pm
Thanks, it need a lot of work. I need a oversize piston and rings, do you know a good sight to go to, wood like. thanks .
Re: my mt500
Post by Wirralman » Thu Oct 03, 2019 6:50 pm
Sportax are the people to talk to about MT engines The owner, Gary, has forum name Minter
Derrick
Re: my mt500
Post by Derrick » Thu Oct 03, 2019 8:51 pm
Welcome to the forum. Sportax and Force are two suppliers of Rotax parts and both can supply overseas.
1997 HD MT350
2002 Honda Pan European 1300
2015 Honda CB500F
Re: my mt500
Post by twmtomos1 » Fri Oct 04, 2019 7:41 am
welcome from Wales uk ,the frame numbers only go up to two hundred and start at zero again with the new frames,there must be a digit some were to make it a diffrent frame if im correct,good luck with the bike
Re: my mt500
Post by Wirralman » Fri Oct 04, 2019 2:39 pm
twmtomos1 wrote: ↑
Armstrong made
Evaluation models
UK police , I think the frames started MP
UK Post Office, frame numbers -unknown
number of these models
UK MT500 Army, kick start only 1985 - 1987/8 ? About 3000 produced ?. I would be absolutely amazed if the same frame number was re used within the same year code
UK CV500 Sheffield parks, frame numbers CV 00001 to CV00028 ? Electric start 560 ? engine, different forks, no pannier frame
Canadian MT500 Electric start, production run 75 ?
I did have the MT 500 format but it lost in the mists of time, I can't believe that they would ever use zero.
dick sauve
Re: my mt500
Post by dick sauve » Wed Oct 09, 2019 9:11 pm
does a kick start work on a electric start mtc 500 Canadian.
Re: my mt500
Post by Wirralman » Wed Oct 09, 2019 9:40 pm
dick sauve wrote: ↑
Yes, the MT350 has both electric and kick , both of which are functional. I would assume that the MTC has the same functionality.
If your battery dies suddenly (I've had a battery start the engine from cold then not have enough power to turn the engine over 20 miles (32km) later with a hot engine), then the kick start can be used. However, there is a knack to kick starting.
The UK kick start only 500 has a decompressor lever to allow you to turn the engine into the right position to start your kick. The right positìon is found by feel or by looking at the white marker that you should be able to view through the sight glass. The marker should be at the 12 o'clock position.
If you look through the forum there is a large thread about kick starting techniques used
P.I.STAKER
Re: my mt500
Post by P.I.STAKER » Thu Oct 10, 2019 8:03 pm
Hi and welcome to the forum
