MT 500
bobdom7
MT 500
Post by bobdom7 » Mon Apr 15, 2019 3:23 pm
Ignition system no spark
sparky
Re: MT 500
Post by sparky » Mon Apr 15, 2019 4:15 pm
Try a new sparkplug. Take the plug cap off and see if theres a spark against the cylinder head if so try a new cap. Then if no spark try a new coil.
Dave.
1994 MT350
1960 AJS model 20
1960 Matchless 650 CSR
1999 BMW F650ST
Re: MT 500
Post by twmtomos1 » Mon Apr 15, 2019 5:02 pm
welcome from wales ,the on off switch on the handlebar near the throtle works the opposite way,may be some one here can post a picture ,good luck
Derrick
Re: MT 500
Post by Derrick » Tue Apr 23, 2019 4:24 pm
Welcome to the forum. Now you have made your first post, you should see more of the topics.
Best to post your technical problems and queries in the "problems aired" section. Worth having a look through and using the search as there can't be many issues that have not been covered.
1997 HD MT350
2002 Honda Pan European 1300
