Posting on the Forum
YOU MUST READ BEFORE POSTING
Post by Wirralman » Tue Nov 13, 2012 2:38 pm
Hi Guys
You may have noticed Bunker's requests for you to 'Post in the right section' and wondered why he gets so agitated about it.
The bottom line is that it takes HOURS to move posts about out of General and into the right area. If they are posted in the right area, it makes forum housekeeping sooooo much easier PLUS it makes the information much easier for people to find in the future.
What I've done is to add some sections to make it easier, so if you have technical problem please can you enter it into the right section. I list below the areas to chose from,
Also, can you make your titles meaningful. A title of "Advice Needed" is a real pain "Advice Needed- Exhaust", makes housekeeping sooooo much easier
Thanks, Eric
Technical/Problems Aired/Questions asked
Frame/Suspension
Electrical
Engine
Carbs & Exhaust
Other
Paint/Powder Coating
Reliability/Performance/MPG/Size/Weight
Wheels/Tyres/Brakes/Chain /Sprockets
350/500/560/604/Other?
Fuel Tanks/Fuel filters
Panniers/Luggage/Racks/Seat
Controls & Instruments
Starting Problems
Clutch/Clutch cable adjustment & Fitting
Tools/Welding/Waterproofing/Loctite/How to do?
MOT
Plastics/Plates/Screens/Headlamp guards
